factory looking paint for omni lcas
I'm picking up some omni lcas, I don't care for the bling, I'm just replacing the factory ones because of the damn bushings/bolt.
I want to paint the omni's black, and hope they look like the new hondas painted suspension parts. Any suggestions?
How would I go about painting the lca's the proper way?
Same here i want take my omni lca's and paint them white to go with my te'37's i would suggest sanding them down with 1000,1500,2000k grit sandpaper work your way up. Then do a light primer and paint them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback »</TD></TR><TR><TD CLASS="quote">Flat black most likely.
Why not buy some Black Blox lca's?
didn't know much about the blox, especially not that they came in black.
just checked em out, look good. Hopefully they're available locally. I want to put these on quick. We'll see.
Err, Get them powdercoated...spraypaint is most likely going to flake because they are constantly getting sandblasted by just driving on any roads. However, for a 5 dollar job, you cant complain..but if you want them to outlast spraycan jobs by years..powdercoat them.
id just take some 500-600 sand paper to them give em some tooth, spray a coat of primer, and a coat of Satin Black(semi-flat) then stick em back on, should be fine for a while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX »</TD></TR><TR><TD CLASS="quote">id just take some 500-600 sand paper to them give em some tooth, spray a coat of primer, and a coat of Satin Black(semi-flat) then stick em back on, should be fine for a while</TD></TR></TABLE>
I agree.
I agree.
yeah I've heard the stories, I thought they corrected the problem w/ the new model. WTH? Can't they do anything right?
I've heard most of these cheap lca's use basically the same cheap bushing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyb3rjak »</TD></TR><TR><TD CLASS="quote">dont get omni!! i have some i got the new model. i just took it off a few days ago and the bushing is shot.
that thing now slides around if i press it with my fingers</TD></TR></TABLE>
You most likely got a defective part, everyone elses are perfect.
that thing now slides around if i press it with my fingers</TD></TR></TABLE>You most likely got a defective part, everyone elses are perfect.
Oh so nice. Message me if you want a set. Best prices!
</TD></TR></TABLE>Oh so nice. Message me if you want a set. Best prices!
