Exhaust system term: Bottle Neck
Old Apr 24, 2002 | 08:03 PM
Hard2Find's Avatar
Default Exhaust system term: Bottle Neck
ok, what do you guys mean by BOTTLE NECK when it comes to exhaust?
can someone explain that to me please?
thank you
Old Apr 24, 2002 | 08:17 PM
SMSP's Avatar
Default Re: Exhaust system term: Bottle Neck (Hard2Find)
Prime example of ITR bottle neck. It's when the gases of a larger tube flow into a smaller tube that has an abrupt change in diameter. This will generate turbulence.
Now a taper is completely different. The gases still go from a larger tube to a smaller tube however this is accomplished by using a smooth taper in the tubing versus an abrupt change. Here's a picture of a taper that goes from 2-5/8" OD to 2-3/8" OD.
Old Apr 24, 2002 | 08:18 PM
py1188's Avatar
when a larger pipe flares down to become a smaller pipe, similar to a bottleneck. Ususally done for noise restrictions
Old Apr 24, 2002 | 08:39 PM
Hard2Find's Avatar
Default Re: Exhaust system term: Bottle Neck (py1188)
so, most Aftermarket catback exhaust is like this?
Old Apr 24, 2002 | 08:50 PM
Chris's Avatar
the "bottleneck" on the Integra B pipe is to make sure the cat is up to temp, for emmisions control.
The term "bottleneck" refers to the slimmest point, or point of highest restriction...like a bottle neck.... and can be used in many contexts.. not just exhaust
trancend
Welding / Fabrication
18
Oct 10, 2013 05:03 PM
2k.civic.si
Nov 10, 2010 08:36 AM
