Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
***** JHPUSA.com August Specicals*****
Old Aug 10, 2006 | 08:02 PM
Gump's Avatar
Default ***** JHPUSA.com August Specials*****
<FONT COLOR="green"><FONT SIZE="3">Rota Group N 15x6.5 Rims</FONT></FONT>
Rota Group N 15x6.5 / +40 offset / 4x100. Other colors avail please call. NOTE: price is for a set.
$399.00USD
[B]<FONT COLOR="green"><FONT SIZE="3">Mugen White NR Racing 15x6.5 Rims</FONT></FONT>
Mugen NR Racing Rims in WHITE 15x6.5, 4x100 +45, approx 17lbs. Note: the price is for a set of 4. IN STOCK....
$1,170.00USD
[B]<FONT COLOR="green"><FONT SIZE="3">Work Lightweight Extended Lug Nuts</FONT></FONT>
WORK open-end extended lug nuts are super lightweight and strong. Made from aluminum alloy, these units are lighter than most aftermarket lug nuts on the market. NOTE: the price is for set of 20.
$114.99USD
[B]<FONT COLOR="green"><FONT SIZE="3">BLOX EF/DA/EG/DC2 Rear Lower Control Arms</FONT></FONT>
These BLOX rear lower control arms are made of forged aluminum. The LCA's are strong and remove about 2.5 pounds. They also have sway bar provisions and hard rubber bushings. They are the same dimensions as stock and bolt right in with no modifications. New design in black or silver. Please specify a color in the comments box.
$99.00USD
<FONT COLOR="green"><FONT SIZE="5">Most of these items can also be combined with our coupon, click on the link below for more info.</FONT></FONT>
Newly added special
We're proud to announce that we've just received a shipment of Skunk2 Fit lowering springs!
  • Skunk2 Racing lowering springs give your car superior handling performance and an aggressive stance with an extra smooth ride. The same engineering and quality that goes into our racing springs also goes into all of our lowering springs. Each spring is CNC-wound using SAE 9254 spring steel, shot peen stress relieved, and corrosion protected using phosphate and powder coatings. The result is a spring that specifically offers racecar handling, yet maintains smooth and comfortable ride characteristics.
  • Skunk2 lowering springs lower the Honda Fit approx. 1.5" front and 1" rear.
  • Spring Rates: Front - 350lbs , Rear - 175lbs
  • Skunk2 Fit Lower Springs PDF
For pricing, please PM / Email (info@jhpusa.com) / or call 626.287.5000 - thanks.
Approximate stance of vehicle with springs installed:
Modified by Gump at 5:29 PM 8/21/2006
Old Aug 10, 2006 | 08:54 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: ***** JHPUSA.com August Specials***** (Gump)
JHP for sure
Old Aug 11, 2006 | 08:52 AM
Gump's Avatar
Old Aug 17, 2006 | 11:53 AM
Gump's Avatar
Old Aug 17, 2006 | 08:01 PM
ES2's Avatar
ES2
Can we use the coupon on the Mugen wheels?
Old Aug 17, 2006 | 08:55 PM
Gump's Avatar
Default Re: ***** JHPUSA.com August Specials***** (ES2)
Yes you can.
Old Aug 20, 2006 | 10:07 PM
Gump's Avatar
vital123
Mar 11, 2010 05:36 AM
96 SOHC VTEC
Jun 7, 2007 04:17 PM
vtecfed
Feb 15, 2005 02:19 AM
LOOKALIKe_eh2
Oct 28, 2004 11:42 AM
