does my trannie have oil cooler lines????
Old Aug 10, 2006 | 07:27 PM
crxsteve's Avatar
Default does my trannie have oil cooler lines????
ok i have a 91 b18a1 with the LS trannie
and there is 2 tubes comein out of the back where i put the speedo cable line in at
i just bought a rattie for ab 91 crx si
and it has oil cooler lines
so i was thinking about running them tubes from the back of the trannie up to them
or
did i get the wroge trannie for this motor??????
thanks for any help
Old Aug 10, 2006 | 08:00 PM
mrtoastyjr's Avatar
Default Re: does my trannie have oil cooler lines???? (crxsteve)
the tubes coming from the speedo cable are for power steering fluid. theres something with the tegs, i believe, that the faster you are going the less steering assist you will have, some one correct me if im wrong.
just get a speed sensor without those lines, like you stock one, and don't worry about the cooler lines coming off your rad. i have an auto rad to. i dosen't fit very well but i got it for free. eeehhh, whatever.
Old Aug 10, 2006 | 08:03 PM
crxsteve's Avatar
Default Re: does my trannie have oil cooler lines???? (mrtoastyjr)
oh well can i run it with those tubes beeing like that ???
and i well just take the rad back if it's a auto one
later
Old Aug 10, 2006 | 08:08 PM
mrtoastyjr's Avatar
i dont know if you can run the senor like that. actually i think they make a loop hose that goes from one port to the other and then fill it with power steering fluid. i think if you run it without fluid it will over heat and seize.
as for the rad, how many lines are coming from it. if it does have a cooler the there will be two smaller lines on the bottom tank, usually having a 90 degree angle in them. plus the 2 line for the rad hoses.
if you did indeed get an si rad then there shouldn't be any cooler, since the si didn't come with an auto trans
Old Aug 10, 2006 | 08:20 PM
crxsteve's Avatar
yea well i am takeing it back tomarro and getting the rite one
thanks for the help i am gonna make a loop for the trannie and fill it
my car don't have power steering
the car is really a hf
thanks for the help
later
GPNY
Welding / Fabrication
19
Jul 11, 2009 10:53 PM
russianswty
Feb 4, 2007 08:07 PM
Origin
Jan 23, 2004 08:35 AM
ScottEK
Mar 18, 2003 09:36 PM
jrcrx
Jun 19, 2002 09:36 PM
