B20 supercharged integra ?
Old Aug 10, 2006 | 06:40 PM
CUL8RI1's Avatar
Default B20 supercharged integra ?
I have a JDM B20B in my 95 teg and its got the B18B crank pulley on it. I plan on installing my JRSC on it. Will the psi be lower than it should be with this pulley? Should I put the B20 pulley back on the motor?
Old Aug 11, 2006 | 05:53 AM
CUL8RI1's Avatar
Default Re: B20 supercharged integra ? (CUL8RI1)
bump ^^^
Old Aug 12, 2006 | 08:04 AM
CUL8RI1's Avatar
Any know what PSI the CRV pulley gives?
Old Aug 12, 2006 | 09:01 AM
Sumslapper's Avatar
Year 3030
crv pulley nets 10psi i beleive
Old Aug 12, 2006 | 09:45 AM
CUL8RI1's Avatar
Default Re: B20 supercharged integra ? (sumslapper)
cool, so the crv pulley gives 10 psi on the b18b and on the b20?
Cause im running the b20 engine.
Old Nov 25, 2007 | 10:22 PM
sepetinswenze's Avatar
NO, the CR-V crank (B20b crank pulley) will net around 9-10psi on most motors, but the B18b crank pulley will only be aroun 6-7psi. So find a CR-V crank pulley and use it with the rest of your setup...
enjoy.
Old Nov 27, 2007 | 05:28 PM
Brad Pitts's Avatar
sorry guys u do understand that the crank pully dosent turn the charger..... the alternater pully dose.and the only way u can change the boost is with the supercharger pully it self
Old Nov 28, 2007 | 10:13 AM
95 integra's Avatar
Default Re: (Brad Pitts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brad Pitts &raquo;</TD></TR><TR><TD CLASS="quote">sorry guys u do understand that the crank pully dosent turn the charger..... the alternater pully dose.and the only way u can change the boost is with the supercharger pully it self </TD></TR></TABLE>
Sorry, you are wrong. What turns the alternator? Oh wait...the crank pulley. Oh and wait....the B20 and GSRs have different size pulleys on the crankshaft for the alternator (the GSR revs higher, thus they made it so it turns the alternator slightly slower). Thus, by changing the crank pulley, you change how many times the alternator (and supercharger) turn over per crank revolution and effectively raise boost with running a different crank pulley. I'm not sure how you thought the alternator pulley turned the supercharger because it might as well be a tensioner for the S/C pulley that effects nothing at all. You can change the alternator pulley and it wont make a difference on the S/C or crankshaft either.
Old Nov 28, 2007 | 10:28 AM
Schister66's Avatar
Man U FTW
You have a point. The alternator pulley can be changed in order to alter the gearing between the supercharger pulley and the alternator pulley. Similarly, the crank pulley dictates the speed at which the alternator pulley turns; therefor, you can adjust both in order to get the most out of your JRSC
Old Nov 30, 2007 | 12:19 AM
Brad Pitts's Avatar
Default Re: (Schister66)
sorry someone posted on my account n i corrected him on it. both previous posts are right both the altenator pulley n crank pulley to make a diff in how much boost u obtain on a sc. they way it looks to me on the sc kit endyn puts out for the d series that makes 20psi on a jrsc is by a larger crank pulley. im not sure if they use a diff altenator pulley or not. but anyone that can make a sc d series make over 400whp is doin somethin right
civicjason
Feb 28, 2010 06:37 PM
JJtegfan14
May 26, 2009 01:27 PM
ninetysevenITR
Mar 29, 2009 11:23 AM
integrated civic
Apr 2, 2006 10:52 AM
