'95 Accord a/c
Old Aug 10, 2006 | 06:00 PM
benboy's Avatar
Default '95 Accord a/c
i have a problem with the a/c not cooling.... replaced compressor, condensor, expansion valve, dryer. evacuated and recharged.... still cools marginally going down the road and gets increasingly hot in town or stop and go. the condensor fan runs but sometime i find it does not start and the airflow is questionable. i have a new one ordered but i saw a post somewhere earlier in which someone quoted similar symptoms and said the found the"thermostat" to be bad. is there an actual thermostat somewhere that i am not aware of ... he quoted it was "somewhere" behind the glove box .....the only thing i am aware of behind the glove box area is the evap coil and the expansion valve. am i wrong on this .....is there a thermostat that could be bad and, if so, exactly where is it ....i assumed temp was controlled by regulating water flow through the heater coil.....thanks for any help.
Old Aug 10, 2006 | 10:29 PM
Honda-Master's Avatar
Default Re: '95 Accord a/c (benboy)
http://www.hondaaccordforum.com
ask for deserthonda
myheadhertz
Sep 11, 2018 06:59 PM
TeknoGodz
Apr 19, 2015 11:30 PM
bunnyx
Mar 18, 2009 08:52 AM
vtecgsr98
Apr 2, 2006 04:29 PM
