Best OBD1 computer for ZC engine?
Old Aug 10, 2006 | 04:40 PM
baboracus's Avatar
Default Best OBD1 computer for ZC engine?
Howdy, I have a 1990 civic hatch with a 1.6 DOHC ZC in it. I was wondering which computers would be the best to upgrade it to an OBD1.
Old Aug 10, 2006 | 05:12 PM
savinGAShaulinAss's Avatar
Default Re: Best OBD1 computer for ZC engine? (baboracus)
dohc zc motors were only obd 0. now i can only suggest a couple of things.
1. get an obd1 d15 non vtec ecu
2. get an obd1 b18 dohc non vtec ecu
i would think the d15 ecu would work maybe a little lean if that i dont know.also the b18 might work and it may run a little rich. like i said its only a guess. hope it helps.
Old Aug 10, 2006 | 05:16 PM
zCivic's Avatar
Default Re: Best OBD1 computer for ZC engine? (savinGAShaulinAss)
They had OBD1 ZC.. if your going OBD1 get pretty much any OBD1 integra/civic ECU other then the CX ones, and have it socketed and programed with the ZC maps.
Old Aug 10, 2006 | 05:29 PM
Default Re: Best OBD1 computer for ZC engine? (zCivic)
sorry bout the info. from what i read in my honda engine swap guide it only had 2 versions of the zc motor and they were both 0bd0.
Old Aug 10, 2006 | 06:27 PM
zCivic's Avatar
eh have to learn some wheres. There were 2 obd0 ZC brown and black topped. Not 100% positive but I believe the OBD1 were mainly used in Rovers and such.
suspendedHatch's Avatar
You're correct because he said DOHC. There were many versions of the SOHC ZC however.
You need a first gen Integra ECU. You do not want to upgrade to OBD1 with that motor.
Old Aug 11, 2006 | 05:11 AM
zCivic's Avatar
Default Re: Best OBD1 computer for ZC engine? (suspendedHatch)
Actually the PG7 ECU is to rich for the motor. Not sure why but I've known of 2 different ones and the were really rich but put in a chipped ECU with a PM7 rom and they run quite a bit better. This was a PM7 stock rom dump with no tuning and it ran quite a bit better.
Old Aug 11, 2006 | 12:39 PM
baboracus's Avatar
hmm, well the primary incentive was to be able to have OBD1 so i could use the Hondata S100 system. Then probably tune the car to use 105 octane E85 as a daily driver.
D7_62
Classic Hondas
Aug 6, 2012 07:36 AM
ZC CivicJdm
Jun 15, 2006 12:14 PM
. M i c h a e l
Mar 25, 2006 02:59 PM
deerek101
Feb 5, 2006 09:44 PM
clsmooth
Nov 18, 2003 11:24 AM
