Trasmission Slipping Need Help Please
Transmission seems to be slipping. slips from 1-2, 2-3. 3-4 and sometimes it won't even go into gear. It's on a 95 accord , f22b1 motor. How can I fix it. New trans? Torque converter? As far as I know the trans computer is fine. no burnt out resistors or anything. I need help with this please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowsinthe20s »</TD></TR><TR><TD CLASS="quote">Transmission seems to be slipping. slips from 1-2, 2-3. 3-4 and sometimes it won't even go into gear. It's on a 95 accord , f22b1 motor. How can I fix it. New trans? Torque converter? As far as I know the trans computer is fine. no burnt out resistors or anything. I need help with this please. </TD></TR></TABLE>
Need to ask you to describe the slipping further. Is it slipping from one gear to the other? Or is it slipping -- not holding the engine revs, where the engine spins faster but the car is losing power and speed? If it is the change of gears, then it might just need a flush/change of auto trans fluid. If it is the second, then it might be your clutch packs, and the need to rebuild or replace the trans.
More like the second one you described. The more engine revs it loses power. Sometimes it shifts sometimes it doesn't. Also if I turn the car off and then start it again it seems to be better for a minute then it starts again. Motor spins faster then doesn't shift. I guees I need a new trans. Thanks for the info.
ZekeZG
Apr 7, 2016 05:56 AM
ctoFAB
Oct 22, 2013 10:42 PM
ender214
Aug 22, 2011 08:42 AM
EK FLY
Jul 5, 2011 05:15 PM
nhldogg
Feb 7, 2010 11:52 AM
