Which headgasket? LS or B20
Old Aug 10, 2006 | 03:52 PM
2ndgentegracer's Avatar
Default Which headgasket? LS or B20
I spun a bearing in my LS block, and found a B20 block locally that I'm gonna pick up. I'm gonna throw the LS head onto it for awhile until I can go B20/VTEC. Now my question is which headgasket do I use, the LS or B20. Is there anything else that I would need to swap it over to the B20 block, there aren't any sensors I need are there?
B20 block, LS head.
TIA
Old Aug 10, 2006 | 06:52 PM
Ruben19's Avatar
need a b20 headgasket because the b20 has a 84mm bore compare to the ls 81mm
ls and b20 everything else is the same.
the only difference is the bore
Old Aug 10, 2006 | 07:13 PM
dmacaalay's Avatar
Default Re: (Ruben19)
b20 gasket and all else is plug n play.. good luck man..
Old Aug 11, 2006 | 03:16 PM
Default Re: (dmacaalay)
Ok cool, those were my thoughts exactly. I figured the headgasket would be the B20. Thanks Guys, just needed confirmation.
93h2beg
Feb 12, 2013 12:16 PM
b20veghathc
12
Oct 5, 2010 07:16 AM
ALLMOTA92EG
Feb 6, 2005 11:28 PM
who00knows
Feb 20, 2003 02:18 PM
