B-swap, speedo doesn't work now
Old Aug 10, 2006 | 03:17 PM
mahatma's Avatar
Default B-swap, speedo doesn't work now
Well this is probably my fault because I let the entire old engine hang by the speedo cable when I was pulling it out.....didn't realize it was even there
Anyway after the swap, the speedo doesn't work. It will occasionally twitch like it's rubbing. I thought maybe I snapped the cable, so I got another from the junkyard. I noticed in the junkyard car, that the cable itself stuck out when I unclipped it (like a TV cable would look). When I thread the cable up to the cluster, it doesn't protrude like it should. It's not even visible when the cable is plugged into the transmission.
So what the hell happened? I can't really see where it comes into the cabin.....
OH, 1 more thing: Is the cable's sheath supposed to fit inside the metal end that plugs into the transmission? That could definitely be the problem..
Modified by mahatma at 7:32 PM 8/10/2006
Old Aug 12, 2006 | 08:11 AM
mahatma's Avatar
Default Re: B-swap, speedo doesn't work now (mahatma)
Can anyone tell me if the black "guard" over the cable fits into the metal end by the transmission?
Old Aug 12, 2006 | 08:20 AM
ludesrv's Avatar
Take a picture.
GPC91
Sep 17, 2012 01:11 PM
crxblues
Dec 6, 2006 10:44 AM
meseetree
Jun 2, 2006 07:19 AM
