feeding the speedo cable through the firewall??
How do you feed the speedo cable through the firewall?? I can't seem to find the opening through my car to the engine bay.. What did you guys do and how did you feed it through?
if the old one is still in the car, attach the new one to the trans. end of it then pull it up through the cluster. Otherwise, it's a bitch. Try getting a penlight and put it in the engine bay side of the hole and then look for the light.\
*edit* you can also just undo the 6-8 bolts (been a while, can't remember now) and take the dash out.
Gaz
Jan 11, 2002 10:24 AM
