Washed the hatchy and updated pics with the new wheels..
Old Aug 10, 2006 | 03:09 PM
DohctorVtec's Avatar
Default Washed the hatchy and updated pics with the new wheels..
I attempted to wash up the Engine bay my first REAL attempt was kinda nervous getting things wet... but tell me what you think of the new wheels and the engine bay thaaanks!! ?
Old Aug 10, 2006 | 03:10 PM
prayludin's Avatar
Default Re: Washed the hatchy and updated pics with the new wheels.. (DoctorVtec)
JuggsXanvi's Avatar
clean , get a stock ex/si lip and its perfect
Old Aug 10, 2006 | 03:11 PM
00ekcoupe's Avatar
Exterior looks awesome.. but the engine bay needs some TLC.
Old Aug 10, 2006 | 03:12 PM
-Gambit-'s Avatar
Default Re: Washed the hatchy and updated pics with the new wheels.. (k24project)
looks good, you should try some engine degreaser or brake cleaner on your engine and trans to get off alot of the dirt.
Dforce's Avatar
That's what she said!
good start.
Old Aug 10, 2006 | 03:14 PM
rufridn's Avatar
nice paint
Old Aug 10, 2006 | 03:16 PM
DUFFM4N's Avatar
Default Re: (rufridn)
ex front lip and a spoon spoiler and then itll be PERFECT...but ur paint is clean
Old Aug 10, 2006 | 03:17 PM
-Gambit-'s Avatar
Default Re: (DUFFM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">ex front lip and a spoon spoiler and then itll be PERFECT...but ur paint is clean</TD></TR></TABLE>
Old Aug 10, 2006 | 03:20 PM
another silver ej8's Avatar
simple green works really well and a high pressure sprayer
Sa.L.aS's Avatar
Carpe diem!
Old Aug 10, 2006 | 03:21 PM
roll5104life's Avatar
looks amazing from the outside and a lil work under the hood and it will be golden
Old Aug 10, 2006 | 03:25 PM
Default Re: (roll5104life)
Yeah I did use Simple Green but I was nervous getting water where the plug wires are.. I did cover my MSD Blaster Coil SS, Dizzy, Airfilter, and Fuse Box. But I was still nervous and only sprayed water lightly over the engine bay. I just need to know what to do exactly when pressure washing an engine bay because I do have a Honda Pressure Washer... Any tips? on how exctly to do it..
Old Aug 10, 2006 | 03:37 PM
TeH PLAYA's Avatar
Default Re: (DoctorVtec)
so you did pressure wash your bay? it just looks a lil faded?
if so, use armor all
and nice paint. blades
Old Aug 10, 2006 | 03:38 PM
E46Kid's Avatar
Default Re: Washed the hatchy and updated pics with the new wheels.. (Dforce)
Very well kept
Old Aug 10, 2006 | 03:41 PM
Default Re: (TeH PLAYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeH PLAYA &raquo;</TD></TR><TR><TD CLASS="quote">so you did pressure wash your bay? it just looks a lil faded?
and nice paint. blades </TD></TR></TABLE>
Nah I didnt use pressure washer just used the shower nozzle on my regular house house..
Old Aug 10, 2006 | 03:50 PM
DJslepton's Avatar
cover your battery & distributor w/plastic bags and get some engine foam cleaner. let the engine warm up for less than 5 mins then spray it on and make sure if there some grimey areas that need scrubing due that w/ a wire brush then let it sit for 1o mins or so, then hose it down w/ a garden hose or something u should be good
Old Aug 10, 2006 | 03:57 PM
LoSt is BlaCk's Avatar
Default Re: (sleptonEH2)
Old Aug 10, 2006 | 04:11 PM
FernEF's Avatar
Old Aug 10, 2006 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleptonEH2 &raquo;</TD></TR><TR><TD CLASS="quote">cover your battery & distributor w/plastic bags and get some engine foam cleaner. let the engine warm up for less than 5 mins then spray it on and make sure if there some grimey areas that need scrubing due that w/ a wire brush then let it sit for 1o mins or so, then hose it down w/ a garden hose or something u should be good </TD></TR></TABLE>
Ok but what about with the plug wires are? last time I did that water got into there and my car misfired forever! had to use an airhose to quick dry out the plug slots. so what can I use to over that?
Old Aug 10, 2006 | 05:07 PM
dFreezy's Avatar
don't forget to remove the spray paint off your calipers
Old Aug 10, 2006 | 05:15 PM
Tad's Avatar
Tad
hehe,
dude, when I wash my engine bay,
I just go crazy with the pressure washer, simple green. I spray it PLENTY
I used to bag off my dizzy and alt and air filter.
but honestly the only thing I bag off now is the distributor and I just pull the intake off and stick a rag in the throttlebody(helps me get at everything under the intake.
everything in your engine bay is designed to be water tight.
Maybe that msd stuff isn't though, cuz it's not oem.
Your plugwires sould seal just fine,
if not then they're probly bad or something..
Old Aug 10, 2006 | 05:22 PM
JDMorgan's Avatar
nice car. now paint the bay.
Old Aug 10, 2006 | 05:30 PM
gsus805's Avatar
Default Re: Washed the hatchy and updated pics with the new wheels.. (-Gambit-)
cool
Old Aug 10, 2006 | 05:34 PM
Not_So_JDM's Avatar
Default Re: Washed the hatchy and updated pics with the new wheels.. (prayludin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prayludin &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
