how did you mount your eg raditor in your ef
Old Aug 10, 2006 | 12:00 PM
dravesef's Avatar
Default how did you mount your eg raditor in your ef
just like the questions says, going turbo so i cant use my dual core integra raditor any more, so i baught an eg one and i'm looking for the simplest way of doing it. oh yeah and i don't want it to pimp lean toward the motor. so any pics woud help me out thanks
Old Aug 10, 2006 | 12:17 PM
xx89civicracer89xx's Avatar
Default Re: how did you mount your eg raditor in your ef (dravesef)
i have heard of people just getting traction bars (so it takes away the big *** fron cross memeber) then the radiator can slide between the traction bar and front rad. support... then just make a lil bracket to hold it in place... or u could just cut apart of it away if u dotn wana buy the traction bars..
Old Aug 10, 2006 | 12:20 PM
3s0n3's Avatar
not sure if this helps but there is a shot of where i put mine after i built my traction bar .... and to secure it i just made 2 top tabs to hold it in
https://honda-tech.com/zerothread?id=1665396
Old Aug 10, 2006 | 12:21 PM
Minor Threat's Avatar
Default Re: how did you mount your eg raditor in your ef (xx89civicracer89xx)
I hacked the entire passenger side of the lower rad support out so the EG rad can sit low enough to clear the hood. It's just kind of resting in there now, but it's solid and I haven't had an issue yet.
Old Aug 10, 2006 | 12:23 PM
Loserkidwac's Avatar
Before:
After:
JK Crosmember PCM EG half rad and 12" slim fan
Had to fab an upper mount but that was easy it has no clearance issues it does however sid the rad back a little further but there is still a decent amount of space and plenty of room for a turbo and DP
Old Aug 10, 2006 | 12:33 PM
uberhaulin's Avatar
best thing to do is get traction bars and make your own mount..other wise its pimp leaning..
Old Aug 10, 2006 | 12:45 PM
W O T's Avatar
Default Re: (uberhaulin)
I personally cut out my rad bar on that side, mounted the rad as low as I could, just enough so it sat at level with the stock crossmember. Then just for safety I took some fairly thick sheetmetal and made an L with it and welded it to the stock rad support just so it protected the bottom of the rad from bottoming out
Then a few zipties and shes golden and snugged to the front of the engine bay
You really do need to drop the rad down ALOT and CUT the top of your hood webbing to get it to not hit though, thats what I didnt like, but its in there and its mint
Old Aug 10, 2006 | 01:19 PM
dravesef's Avatar
hey thanks guys for the answer and i already have a traction bar and i'm going to cut out the orginal braket then make my own braket so it sits low enought to close the hood so off to home depot i go to get some brakets. thanks by the way that pcm raditor looks nice in that car where did you get it and where did you get the slim fan?
Old Aug 10, 2006 | 01:25 PM
Default Re: (dravesef)
http://www.LSDmotorsports.com
I don't think they have it listed on the website just e-mail them it was a good deal too
Old Aug 10, 2006 | 01:33 PM
dravesef's Avatar
ok cool thanks i'll shoot them a line because your raditor looks better then a stock one
Old Aug 10, 2006 | 01:34 PM
W O T's Avatar
guaranteed Mike @ lsdmotorsports will hook you up
Great customer service and SUPER fast shipping.
He sells pretty much anything, just ask
Old Aug 10, 2006 | 01:40 PM
Default Re: (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">guaranteed Mike @ lsdmotorsports will hook you up
He sells pretty much anything, just ask</TD></TR></TABLE>
hondaguyflozy
May 3, 2009 09:41 AM
hondapimp125
Apr 7, 2008 07:24 PM
pendejon
Feb 12, 2006 08:33 AM
jdm Ef-9
Oct 25, 2005 07:58 PM
technine
14
Oct 3, 2002 07:06 AM
