y8 head on a z6 block (did search)
Old Aug 10, 2006 | 11:46 AM
cutt's Avatar
Default y8 head on a z6 block (did search)
I know they mate up but is there anything to modify. second which head gasket, timing belt , water pump , oil pump do I use y8 or z6 . and third everything for the ecu is in the head, is that correct.
its going in a 1996 civic si coupe with a broken rod in a d16y8 motor
thanks
Old Aug 10, 2006 | 12:11 PM
cutt's Avatar
Default Re: y8 head on a z6 block (cutt)
ttt
Old Aug 10, 2006 | 12:17 PM
bigislandc2's Avatar
it's pretty much a striaght up swap. just change head gasket. thats it. use the z6 headgasket. you should also get a cam gear for it.
Old Aug 11, 2006 | 10:17 AM
cutt's Avatar
Default Re: y8 head on a z6 block (bigislandc2)
why wouldn't the oem cam gear be good enough
Ocnaj
10
Jun 14, 2008 09:38 AM
EfSedanLove
Jan 25, 2008 02:59 PM
The Internet Tough Guy
11
May 3, 2006 05:23 PM
sleepyhamsterlx
Jan 5, 2004 08:21 PM
turbod16y7vtec
Nov 20, 2002 09:22 PM
