Q: just fixed my JDM ITR front bumper sag, but now having problem openin hood!
Old Aug 10, 2006 | 10:16 AM
J.nguyen's Avatar
Default Q: just fixed my JDM ITR front bumper sag, but now having problem openin hood!
well just fixed my JDM ITR front bumper sag. had to flip around the bumper reinforcement bar b/c whoever installed it had it upside down.. but now problem is when im inside the car and i pull the hood latch lever, it dsnt pop open my hood.. i have to go to the front and near the grill pop it from there.. anyone know why its doing this? maybe a kink in the line?? i wanna have any opnions / advise before i take apart my front bumper again.. also hearing this wierd noise from driver side now, sounds like something is hitting when im taking off slowly from 1st gear..
Old Aug 10, 2006 | 11:05 AM
nathanong87's Avatar
Default Re: Q: just fixed my JDM ITR front bumper sag, but now having problem openin hood! (Jesse.)
really they installed the bumper support upsidedown? dang. maybe position ur latch and adjust the height of located with washers. it may still be grabbin ur latch just because of the inital instal? maybe?
Old Aug 10, 2006 | 12:32 PM
J.nguyen's Avatar
Default Re: Q: just fixed my JDM ITR front bumper sag, but now having problem openin hood! (nathanong87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 &raquo;</TD></TR><TR><TD CLASS="quote">really they installed the bumper support upsidedown? dang. maybe position ur latch and adjust the height of located with washers. it may still be grabbin ur latch just because of the inital instal? maybe?</TD></TR></TABLE>
ic.. but expletive jus ran into a problem today.. normally i pop my hood in the middle grill ( b/c my inside lever dsnt work ) and now i think it fell off the clip or something and now it wont pop open.. imma be assed out and pissed if i cant pop my hood anymore.. lol.
Old Aug 10, 2006 | 12:34 PM
RHDintegXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. &raquo;</TD></TR><TR><TD CLASS="quote"> i have to go to the front and near the grill pop it from there</TD></TR></TABLE>
are you saying you have to manually pull on the cable? or only pull up on the hood?
get someone to help you check the latch..pull on the hood latch lever and ask them if they can see the cable moving..if it is my guess is that the hood latch is binding..you can loosen the three 10mm bolts and adjust it the it catches and releases the hood without smoothly and any binding
Old Aug 10, 2006 | 12:50 PM
J.nguyen's Avatar
Default Re: Q: just fixed my JDM ITR front bumper sag, but now having problem openin hood! (SINFULintegXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">are you saying you have to manually pull on the cable? or only pull up on the hood?
get someone to help you check the latch..pull on the hood latch lever and ask them if they can see the cable moving..if it is my guess is that the hood latch is binding..you can loosen the three 10mm bolts and adjust it the it catches and releases the hood without smoothly and any binding</TD></TR></TABLE>
yeah i gotta manually pull the cable.
Old Aug 10, 2006 | 12:53 PM
bboysake's Avatar
wow you are ahving a whole buncha problems huh?
Old Aug 10, 2006 | 01:40 PM
J.nguyen's Avatar
Default Re: (bboysake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboysake &raquo;</TD></TR><TR><TD CLASS="quote">wow you are ahving a whole buncha problems huh?</TD></TR></TABLE>
yeah, once you fix one thing, another thing goes wrong. seems to be my pattern..
*EDIT FIXED IT. hood wire fell off the lil hook and the little ball was extended way too long so had to pull the little ball and put the lil thing back on the hook and now everything works
Modified by Jesse. at 7:34 PM 8/10/2006
Old Aug 11, 2006 | 07:28 AM
bboysake's Avatar
Default Re: (Jesse.)
Good congrats man! I wanna get one but hopefully I dont have that many problems...post up some pics!
Miss_Beccaxo
Paint and Body
Dec 16, 2012 09:03 AM
Rays_07
Paint and Body
Feb 24, 2008 05:56 PM
b20acura
Feb 4, 2007 09:37 AM
88 civic ef
May 31, 2006 07:51 AM
Rishiras
Aug 4, 2004 11:05 AM
