Coolant reservoir low???
Old Aug 10, 2006 | 09:24 AM
RGoose18's Avatar
Default Coolant reservoir low???
I just checked my coolant reservoir and it's a hair below the min level. What kind of coolant do I add to get it back up to the max level? Do I need to mix it w/ water? Excuse the retardo post but I've never added any coolant to either my R or GSR. Thanks
Old Aug 10, 2006 | 09:42 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Coolant reservoir low??? (RGoose18)
Well if its not the new Honda blue stuff then I would flush it out and use that...
Old Aug 10, 2006 | 09:44 AM
gogogomoveit's Avatar
you can either get pre-mixed or pure coolant from auto part stores. Pre-mixed are ready for use and just pour it into the reservoir. For pure cooolants, you need to mix it with water at a 1:1 ratio, and it will be good. Ideally u should use purifed water to get rid of the ions that causes rust, but i have been using tap water and no problem.
Old Aug 10, 2006 | 09:45 AM
RGoose18's Avatar
Default Re: Coolant reservoir low??? (walker111)
Can you please elaborate, what new honda blue stuff?
Also, would it be detrimental to just add some more wal-mart brand coolant and flush it out at a later date
Old Aug 10, 2006 | 10:12 AM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">Can you please elaborate, what new honda blue stuff?
Also, would it be detrimental to just add some more wal-mart brand coolant and flush it out at a later date</TD></TR></TABLE>
Honda's coolant is now blue in color. Its been that way for ahwile, it use to be green. You could buy some walmart stuff and fluch it at a later date.
Old Aug 11, 2006 | 07:20 AM
PocketRocket11's Avatar
The blue stuff is good for at least 6 whp.
Old Aug 11, 2006 | 07:33 AM
len's Avatar
len
Default Re: Coolant reservoir low??? (PocketRocket11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PocketRocket11 &raquo;</TD></TR><TR><TD CLASS="quote">The blue stuff is good for at least 6 whp.</TD></TR></TABLE>
Actually it's 6.2345702834377777...
I'd advise you to get your information straight before you post Mr. PocketRocketManPersonYou
Old Aug 11, 2006 | 12:50 PM
Tweakmeister's Avatar
Default Re: Coolant reservoir low??? (len)
Just buy a gallon of distilled water at your local drug store/grocery store. Top it off with that...50/50 mixture isn't necessarily an "ideal" mixture...a heavier bias towards water will yield better performance, as pure water has better thermal properties than coolant (coolant is mostly an anti-corosive).
Old Aug 11, 2006 | 01:02 PM
NorthernXposure's Avatar
Default Re: Coolant reservoir low??? (Tweakmeister)
just pee in it my ******* comment for the month
Old Aug 11, 2006 | 01:04 PM
cool guy name
Default Re: Coolant reservoir low??? (NorthernXposure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthernXposure &raquo;</TD></TR><TR><TD CLASS="quote">just pee in it my ******* comment for the month </TD></TR></TABLE>
You're an *******!!!
Old Aug 11, 2006 | 04:08 PM
Desired_Speeds's Avatar
if its only missing a tiny bit, just use a bottle of bottled water and add until the correct level
Old Aug 11, 2006 | 04:31 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthernXposure &raquo;</TD></TR><TR><TD CLASS="quote">just pee in it my ******* comment for the month </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
I'd advise you to get your information straight before you post Mr. PocketRocketManPersonYou</TD></TR></TABLE>
LOLOLOLOLZ
Old Aug 11, 2006 | 04:38 PM
vtec.dc2's Avatar
if you haven't yet, use any 50/50 coolant
CRXed
Jun 26, 2004 08:19 PM
importdude2000
Jun 4, 2004 02:08 PM
benmasters
May 25, 2003 12:47 PM
T_Rex
Nov 9, 2002 06:21 PM
