EK power window mech parts crossover list...
My girls car is an EK 2dr coupe. Both of her windows weren't functional. The pass side was an easy fix just putting it back on track. The drivers side pwindow mech is done for though, on the actuator arm, the teeth are completely stripped for about a 3 inch stretch and bent down slightly. I have been to 3 different local junkyards over the past couple of days not able to find the pwindow drives side mech.
Are there any other models that use the same power window mech used in the 2dr EK coupe that I can look for? Thanks in advance.
Gotcha, the local junkyards around here barely have any EK's, mostly EG's, ubt never have I seen any hatches though. Thank you for the input.
C'mon now, gimme something to work with. Even if some could verify whether or not there is another model that can work or not that would be great for starters.
