Bogging bad and failed crank
Old Aug 9, 2006 | 11:19 PM
garyc17's Avatar
Default Bogging bad and failed crank
I am getting bogging/ hesitations on the freeway with constant throttle position on my B18c5. It does not occur all the time. Infact it happens very rarely, but when it does, its really bad. If I were to floor it, the bogging goes away. Will a poorly wired alarm affect the full operation of my fuel pump? Or will a faulty alarm module cause my fuel pump to work inconsistently? My alarm was triggered on one occasion when I tried to crank and the fuel pump relay started ticking for a good 30 seconds. Is it possible to just disconnect the fuel pump wiring from the alarm? I got the alarm wired by the alarm retailer. Today, I was unable to crank in the morning. Nothing happened when I turned the key, but there was the usual battery light, oil light etc. I had to put it to the "off" position and recrank before it started. I did not recall the CEL light come on during my first turn of the key to the "on" position. Any advise?
Old Aug 10, 2006 | 03:21 AM
RTW DC2R's Avatar
Default Re: Bogging bad and failed crank (garyc17)
check grounds.
Old Aug 10, 2006 | 05:54 AM
garyc17's Avatar
Default Re: Bogging bad and failed crank (RTW DC2R)
I have sanded almost every ground in my engine bay. Any other ideas?
Old Aug 10, 2006 | 01:50 PM
PoorMansNSX
Guest
Posts: n/a
It may possibly be an 02 Sensor that is fukt. It confuses your ECU, with fuel output.
I used to have the same thing..
Old Aug 21, 2006 | 07:46 PM
garyc17's Avatar
How much does one of those O2 sensors run for? I have a OBD2a harness but I have an EK9 full exhaust, so how many sensors should I have?
dsh7941
Audio / Security / Video
Apr 1, 2007 03:36 PM
OneTyteEK9
Feb 6, 2006 07:56 PM
cxSHOE
Aug 20, 2005 12:46 PM
vietjdmboi
Mar 3, 2005 02:33 AM
(-_-)
Nov 4, 2002 01:19 PM
