P61 Intake manifold better than P30 Intake manifold? SEARCHED
So which is better or are they the same. I know one is b16 and p61 is b17 but does p61 have better flow or bigger ports for air?
Just checking and don't tell me to search because I did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">So which is better or are they the same. I know one is b16 and p61 is b17 but does p61 have better flow or bigger ports for air?
Just checking and don't tell me to search because I did.</TD></TR></TABLE>
They are IDENTICAL minus the additional vac line and different bend found in the brake booster vac connector. They should flow exactly the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempsohc »</TD></TR><TR><TD CLASS="quote">the booster vacuum thing by the throttlebody also sucks...</TD></TR></TABLE>
There is nothing to do withthe booster next to the throttle body. The manifolds are identical at the throttle body side.
