will high compression jdm type s pistons fit in my h23a1 lude
Old Aug 9, 2006 | 09:22 PM
lucyh23's Avatar
Default will high compression jdm type s pistons fit in my h23a1 lude
i got a 94 lude si h23a1 and i thinking about putting those high compression type s pistons in it. Would they fit and is it worth it? I just want to know if it will help me any thanks
Old Aug 9, 2006 | 09:31 PM
AznBlueBoy's Avatar
Default Re: will high compression jdm type s pistons fit in my h23a1 lude (lucyh23)
they wont be 11:1 compression though
somewhere around 13:1?
Old Aug 10, 2006 | 04:24 PM
lucyh23's Avatar
Default Re: will high compression jdm type s pistons fit in my h23a1 lude (AznBlueBoy)
isnt that better than 11:1 im not going to boost it or anything
Old Aug 10, 2006 | 05:14 PM
InvaderTrax's Avatar
As long as you can get your hands on some race gas you'll be fine. You'll never get away with 13:1 on 93 pump gas
Old Aug 10, 2006 | 05:52 PM
twistedbydezign's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucyh23 &raquo;</TD></TR><TR><TD CLASS="quote">isnt that better than 11:1 im not going to boost it or anything</TD></TR></TABLE>
of course 13:1 is better than 11:1, while youre at it only use 1 layer of the headgasket and youll be at 14:1, make sure you use 87 octane too, 91 or higher will hurt your top end and your bragging rights about your peak hp will be lost...
unless youre doing it yourself (god i hope not) the amount of money a shop would charge to rebuild your h23 and put type s pistons in it would be rediculous to get up to probably 160whp on your h23, not to mention you will have to tune because of the 13ish:1 compression, run race gas all of the time, plus get engine management, plus that compression would be useless without some upgraded cams which require upgraded valvetrain, then a good 2.5 exhaust, plus a good header (which nobody makes for an h23 unless you go expensive custom), all before even talking about dynotuning.....read up here before you make any decisions or get back in your car again....
Old Aug 13, 2006 | 09:07 PM
lucyh23's Avatar
Default Re: (InvaderTrax)
so youmean to tell me that iwill have to run race gas in my lude if i get those pistons put in. SO i will be arouind that 11:1 CR or more...????
Old Aug 13, 2006 | 09:11 PM
lucyh23's Avatar
Default Re: (lucyh23)
what if i where to port and polish the head and the intake manifold along with the type s pistons. Would that be alright
Old Aug 14, 2006 | 12:44 PM
BDRphaSe2's Avatar
^^ i think you havbe a lot to learn about motors before you replace pistons....that wont fit wihout mods, but to answer your question go with the h22a1 pistons, their not floating so theyl fit on fine and your compression will be arround 11
lsvtechatch92
Jul 18, 2007 01:51 AM
meanshyguy
Apr 1, 2007 10:23 AM
jdmgsr94
10
Mar 30, 2007 02:29 PM
vteclude559
Oct 29, 2004 04:53 PM
Heisdan
Aug 4, 2003 07:07 AM
