Deciding factors between Spec B and C
Old Apr 24, 2002 | 05:35 PM
itr501's Avatar
Default Deciding factors between Spec B and C
Old Apr 24, 2002 | 05:36 PM
Bob#455's Avatar
Default Re: Deciding factors between Spec B and C (itr501)
Stock cams ownz.
Old Apr 24, 2002 | 05:43 PM
STOLEN - ITR 98-0652's Avatar
Remember, the Cs NEED compression and the Bs LOVE it. Cs may also require larger injectors and other stuff... people run Bs quite effectively with stock CR, stock injectors and stock ECUs (with VAFC, of course).
Also, Cs are rumored to make power higher up on the rev band. Remember Ruins Peoples' Motors - although, technically, it is an engine.
Now, not everyone with Toda Cs has a built-to-the-hilt set-up, but that's what they're for. Race cams, y'know?
So, (1) initial capital cost and (2) long term reliability if used as god intended.
Old Apr 24, 2002 | 05:44 PM
t's Avatar
t
Nothing, get the spec Cs
Old Apr 24, 2002 | 05:49 PM
ITRinEJ1's Avatar
this mite help:
https://honda-tech.com/zerosearch
Old Apr 24, 2002 | 05:59 PM
itr501's Avatar
Default Re: Deciding factors between Spec B and C (ITRinEJ1)
i did search, i didnt see any head to head comparisons.
Old Apr 24, 2002 | 06:20 PM
FSTASNTZ's Avatar
I ran the Spec Cs on stock compression and a two layer gasket for almost a year (came out to about to about 10.9:1 with US pistons). Car made decent power. They do not NEED compression to work, but work well with it....
They will NEED larger injectors. If you do a 440cc injector, then you should be fine on the stock pump...
Jason
Old Apr 24, 2002 | 07:17 PM
Rob Dizzle's Avatar
Default Re: Deciding factors between Spec B and C (FSTASNTZ)
c's have a lumpy idle. they arent very streetabel (everyday driving)
you will have to replace your valve spring more often (im guessing every 20-25k)
b's are not nearly as lumpy.
i think another bob said that the stock cams own
you will have to spend in the range of 1800 to get everything done. plus tuning and any other supporting mods
all for the headache for 15 or so whp
i know austin removed his cams a few months agao, not sure why he did it though...
Old Apr 24, 2002 | 07:19 PM
Michael Delaney's Avatar
https://honda-tech.com/zerothread?id=91710
http://www.importreview.com/reviews/...n3VStyper.html
http://www.importreview.com/reviews/JUN3vsTodaB.html
Old Apr 24, 2002 | 07:21 PM
Reid's Avatar
Global Moderator
Default Re: Deciding factors between Spec B and C (bob46802)
B's and C's have the exact same idle.
[Modified by Reid, 6:22 PM 4/24/2002]
Old Apr 24, 2002 | 07:27 PM
Padawan's Avatar
Darth ModerVader
Spec B's and Spec C's have identical primary and secondary lobes so the idles will be the same. Any differences in the idles would be the result of tuning or other factors, not the cams themselves.
Old Apr 24, 2002 | 08:27 PM
MugenDC2R's Avatar
Default Re: Deciding factors between Spec B and C (Michael Delaney)
We're trying to help this guy decide by giving him accurate info right?
So why post links to Import review's test when he didn't even use the right size injectors and ECU program for the spec C's?
I've heard from a reliable source that Toda is coming out with a cam beyond the spec C (I'm not talking about the vtec killers)
Old Apr 24, 2002 | 08:38 PM
coquinn's Avatar
Default Re: Deciding factors between Spec B and C (MugenDC2R)
Toda sucks.
Old Apr 24, 2002 | 09:07 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Deciding factors between Spec B and C (coquinn)
B's = can be run on a relatively stock motor (stock v springs, ecu with fuel correction), injectors, fuel pump, fuel pressure, etc). they just need to breathe.
C's = MUST have valvetrain, plus all the other happy **** needed to make power
Old Apr 24, 2002 | 09:08 PM
Rob :190:'s Avatar
Default Re: Deciding factors between Spec B and C (itr009)
aren't (or weren't) you running b's with stock valvetrain pat? I know one of the NC guys is (was), just forgot who.
Old Apr 24, 2002 | 09:25 PM
Splat's Avatar
Default Re: Deciding factors between Spec B and C (Brian Spilner 1035)
That would be me. Almost seven thousand miles so far. I tend to keep it out of the limiter, but aside from that, I have no worries.
Old Apr 24, 2002 | 10:00 PM
mafay2's Avatar
New User
If you have money, go with Spec B.
If you have more money, go with Spec C.
It cost a lot to have the Spec B tune right, but even more to have the Spec C tune right.
ricekiller1
Nov 27, 2007 11:25 PM
TypeR15
Feb 2, 2004 02:09 PM
Type-Rare#1248
Jun 10, 2002 10:57 PM
Black R
Dec 27, 2001 12:43 PM
skafia
Nov 27, 2001 11:41 AM
