NEED HELP !!!! 95 GSR SEDAN SIDE DOOR TWEETERS?
Old Aug 9, 2006 | 08:55 PM
95GSRBOI's Avatar
Default NEED HELP !!!! 95 GSR SEDAN SIDE DOOR TWEETERS?
I called the dealers and they don't know the oringal tweeter size for a 95 gsr sedan? I am planning to put in some infinity dome tweeter, but can't seem to find ayone who know the size for it... Can someone tell me the size where I can get the right size of tweeter to substitute the OEM tweeters with components.. Thanks
Old Aug 9, 2006 | 09:04 PM
bpr0422's Avatar
Default Re: NEED HELP !!!! 95 GSR SEDAN SIDE DOOR TWEETERS? (95GSRBOI)
do u have the car?
if so... ruler of some sort...
and measure...
compare with tweeter inner diameter...
too small? make it bigger..
too big?? make a bracket...
Old Aug 10, 2006 | 05:16 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do u have the car?
and measure...
Zing!!
Seriously... Are people honestly this helpless that they don't have the sense to actually measure?? :shakes head:
Old Aug 11, 2006 | 08:25 PM
ef9_pr0jekt's Avatar
Ruler
Old Aug 11, 2006 | 10:41 PM
dc24me's Avatar
the factory tweeter housing is pretty big that it's going to be impossible to find a set of tweeters that will fit in the factory cutout without the oem housing. your best bet is to take out the factory tweeter, remove the old tweeter of the factory bracket, mount the new infinity tweeter on it or hotglue or put a couple of drops of crazy glue to mount it to the back of the grille and mount it back in the door. although in theory, the extra grille might reduce the acoustical transparency, (grille blocks some of the output and alters dispersion characteristics) it's mostly psychoacoustic (in your head), but it gives you a nice clean look.
Old Aug 14, 2006 | 08:31 AM
CB7.v2's Avatar
you'll need a tweeter with the threaded center on the back of it and then use the stock bracket. i know the smaller mb quart tweeters work. otherwise, bring it with you and see what fits.
Old Aug 14, 2006 | 04:08 PM
95GSRBOI's Avatar
Default Re: (CB7.v2)
Thanks guys... I will go check them out.
Old Aug 16, 2006 | 09:33 PM
Turbo(less)DB8's Avatar
I have a 99 dr. in the factory location behind the factory grills i have infiniti perfect 6.1. they fit perfect and look stock.
Old Aug 28, 2006 | 07:28 PM
Default Re: NEED HELP !!!! 95 GSR SEDAN SIDE DOOR TWEETERS? (Turbo(less)DB8)
any updates? hope this went well
Old Sep 8, 2006 | 08:03 PM
95GSRBOI's Avatar
Thanks everyone... I got some alpine dome tweeter that is 1". It fit in there with no problem. Again thanks for the tech info.
Manolo
Jan 30, 2007 12:07 PM
95gsrhead
Audio / Security / Video
Dec 26, 2006 12:23 PM
SnowPro
Mar 2, 2005 05:18 AM
NavyHonda95
Oct 7, 2004 08:06 AM
