D16Z6 / D15B2 mini-me distributor problem
Old Aug 9, 2006 | 08:30 PM
dmcclain's Avatar
Default D16Z6 / D15B2 mini-me distributor problem
I installed a D16Z6 head onto my D15B2 block in my 89 civic, I had heard that the distributor was a direct bolt up... this is a LIE! The d15b2 dist. is way off on the ajustment brackets, I can only get one to line up after shaving some metal out of the hole on the front ajustment on the distributor!!! What can be done????????? I know its not timed right and I dont have much ajustment to work with here...
Old Aug 9, 2006 | 09:23 PM
doublethink's Avatar
Default Re: D16Z6 / D15B2 mini-me distributor problem (dmcclain)
your z6 head came without dizzy?
Old Aug 9, 2006 | 10:03 PM
yz125rider21's Avatar
just explained
https://honda-tech.com/zerothread/1717386
Old Aug 10, 2006 | 05:21 AM
92integra_gs's Avatar
who ever told you that its a direct bolt on just misinformed you...
you can make a bracket for it... or you can grind out the to portion 2 of 3 and use big fender washer... thats how i did mine...
JJDd16z6
Sep 21, 2011 01:44 PM
808DA
May 8, 2009 06:02 PM
jawsiiv
Nov 21, 2008 05:43 PM
thenick
Sep 25, 2004 07:20 AM
HarryB
Aug 13, 2002 09:13 AM
