111K chech engine light came on
Old Aug 9, 2006 | 07:27 PM
eg4usdm's Avatar
Default 111K maintanance required light came on
it just turned over 111K on my gs-r and the mainatance required came on.
i was wondering (i dont have a manual) if there are any specific services that need to be done besides you know the usual
timing belt, fuel filter, distributer.
any help is appreciated.
Old Aug 9, 2006 | 07:32 PM
SmogKing's Avatar
Default Re: 111K chech engine light came on (eg4usdm)
Check to see what code is setting the light to go off.
Old Aug 9, 2006 | 07:34 PM
eg4usdm's Avatar
Default Re: 111K chech engine light came on (SmoGuy)
ooo ****, im an idiooottt
i mean maintanence required light.
o man..
its been a LONG day. sorry guy
Old Aug 9, 2006 | 07:39 PM
Smog09's Avatar
If your ride is running fine, I would'nt service it just yet.
Old Aug 9, 2006 | 07:51 PM
davidluko's Avatar
If it wasn't serviced around 100k then you should do it now.
Old Aug 9, 2006 | 10:52 PM
eg4usdm's Avatar
Default Re: 111K maintanance required light came on (eg4usdm)
well i bought it when it was about 109K and he replaced the timing belt and radiator, i just changed the oil and filter. im about to change the dizzy and fuel filter.
the car runs great, no problems or anything but i just noticed the light came on and i wanted to know if i was missing anything or should i take it to the dealership to have THEM service it. any help is appreciated. thanks alot guys
Old Aug 10, 2006 | 09:49 AM
davidluko's Avatar
Don't change the dizzy unless there's a problem with it, and even then you would only need to replace maye one or two parts of it and not the whole thing. A new fuel filter and air filter are not a bad idea, spark plug wires, and new correctly-gapped spark plugs... that is, if that stuff hasn't already been changed recently.
Old Aug 10, 2006 | 12:02 PM
eg4usdm's Avatar
Default Re: (Hatch_R)
well in the dizzy the points inside the rotor cap are pitting. i need to get a new fuel filter, i just got a new k&n filter on the cai, new oem spark plugs and properly gapped.
is it normal for the service light to come on at 111k?
thanks for the info
Old Aug 10, 2006 | 12:24 PM
gogogomoveit's Avatar
Default Re: (eg4usdm)
I have mine came on at about 115K....yeh they come on every 10000-15000 miles i think. And you can actually turn it off by yourself.
Old Aug 10, 2006 | 06:22 PM
eg4usdm's Avatar
Default Re: (gogogomoveit)
how do you turn it off by yourself?
thanks for the info guys
Old Aug 10, 2006 | 08:10 PM
numbnuts22715's Avatar
you turn the car to the "on" position and press the little button on the right side of the bottom of the dash.
Old Aug 10, 2006 | 09:35 PM
davidluko's Avatar
The button is not on the right side of the bottom of the dash, it's on the right side of the cover under your steering wheel. I think it's green, not sure on that though, and it's in a little black box.
Old Aug 10, 2006 | 10:31 PM
eg4usdm's Avatar
okay, my gf here so i cant check it but in the mean time does anyone have any pics so i know exactly whre to look?
and does the car need to be running? or just the key turned all the way forward?
Old Aug 10, 2006 | 10:56 PM
davidluko's Avatar
I've never had to do it before, but I think you just have to have the key in the II position, not started, but it'll only take a minute to try both ways.
Modified by Hatch_R at 4:29 PM 8/11/2006
Old Aug 11, 2006 | 01:29 AM
eg4usdm's Avatar
hey thanks man i really appreciate it
hows that spoon **** treating you?
Old Aug 11, 2006 | 02:43 AM
xionl1350's Avatar
just turn your car on to the point where all your dash lights pop on but don't start the car yet....and than you press the black button and hold it until the maint. light turns of and than from there you can start your car and it shouldn't be turned on anymore.
Old Aug 11, 2006 | 12:57 PM
eg4usdm's Avatar
Default Re: (xionl1350)
i just reset it,
it was a little black box with a little blue button.
thanks guys for all the help.
Old Aug 11, 2006 | 02:31 PM
davidluko's Avatar
Yea I wasn't sure if it was green or blue. Also, about the Spoon ****, were you talking to me? Because that picture isn't of my car, I just found someone else's interior because I didn't have any good pictures that had a view of that panel.
Old Aug 11, 2006 | 05:38 PM
eg4usdm's Avatar
o yeah i thought it was your car,
oops
well i want one haha
thanks for the pic man
jnb0111
Jan 1, 2016 09:29 PM
dennisjai
Honda Civic (2001 - 2005)
Jul 27, 2006 10:58 AM
SilentHill
Aug 15, 2005 03:37 PM
Intercooler
Dec 27, 2004 10:20 PM
Seedc2
Aug 18, 2001 08:01 PM
