My Big Build Thread - D Series Hybrid
Old Aug 9, 2006 | 07:11 PM
Eyal 951's Avatar
Default My Big Build Thread - D Series Hybrid
Not sure how many of you care, so if nothing else, this will be a progress post for myself I can always dig up later in the archives.
I, for one reason or another, decided to build a D...
The Build:
D16Z6 Bottom end (from 1995 Civic Si VTEC)
-D16A6 (PM6 CRX Si) Pistons
-Completly rebuild and cleaned with new everything
-Bored .040 Over (from 75mm to 76mm bores)
-New Exedy Clutch
-Exedy Lightweight Flywheel
-ARP headstuds
-decked .010
-11.4:1 CR
D16Y8 Head (from 2000 Civic EX VTEC)
-milled .010
-Crower Stage 2 Cam
-Crower valve springs
-Crower Titanium retainers
-completly rebuild and cleaned with new everything
-Skunk 2 Pro Series Intake Manifold
-2 layer head gasket (removes .012)
-AEM Adj. Cam gear
-B16 Throttle boddy (increases from 56mm to 58mm)
-B16 Intake arm
-Apex'i Power Intake
-DC Sports 4-1 Headers
-2.5 inch mandrel Exhaust with 22" resonator, SNL Twin Loop
Enigne Managment
-Socketed and chiped P28 ecu
-Hondata S100 piggyback
Cooling:
-GSR Radiator
Transmition:
-EX/Si Trans
A bunch of new parts like cap and rotor for the dizzy, plug wires, Vtec valve cover and lots lots more.
A couple of photos of the engine and the car its going into.
Modified by Eyal 951 at 8:46 PM 9/15/2006
Modified by Eyal 951 at 3:11 PM 9/23/2006
Modified by Eyal 951 at 5:45 PM 1/11/2007
Modified by Eyal 951 at 2:32 AM 2/8/2007
Modified by Eyal 951 at 2:59 PM 8/1/2007
Old Aug 9, 2006 | 07:12 PM
Eyal 951's Avatar
Default Re: My Big Build Thread - D Series Hybrid (Eyal 951)
This is for the 944 Turbo:
Modified by Eyal 951 at 9:29 AM 8/10/2006
Old Aug 9, 2006 | 07:23 PM
95civhb's Avatar
can't see any pics...
sounds like a good build... what are you shooting for?
what's the point of the 2 layer head gasket? changing the compression some?
Old Aug 9, 2006 | 07:35 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
cant see pics
Old Aug 9, 2006 | 07:59 PM
Froth's Avatar
Default Re: My Big Build Thread - D Series Hybrid (rukawa1one)
Upload the pics here...
http://www.poopftw.com/upload.php
Old Aug 9, 2006 | 08:43 PM
mRek9R's Avatar
Default Re: My Big Build Thread - D Series Hybrid (Froth)
that's a good build! i never got to start my PM7, 12.7:1 c/r d16 project....scrapped it when i finished the block 8(.
Old Aug 10, 2006 | 12:32 AM
Eyal 951's Avatar
Default Re: My Big Build Thread - D Series Hybrid (mRek9R)
Hmm, weird, pics work for me... Are they still not working, if not, tomorrow I'll fix it. Too tired to do it now.
Old Aug 10, 2006 | 04:21 AM
HiProfile's Avatar
They work since you've viewed them, attachments on that site first require you to log in to view them. Any idea on compression?
Old Aug 10, 2006 | 04:22 AM
Honda Bull's Avatar
Nice build and info. Can't see the pics. But good luck with it.
Old Aug 10, 2006 | 04:31 AM
Slothy's Avatar
Default Re: My Big Build Thread - D Series Hybrid (Honda Bull)
The pictures are hosted on D-series.org
You have to be a member there to see them here. I couldn'd see them at first until I logged in there and refreshed this page.
A different picture host will fix this as im guessing d-series doesnt like hot-linking of pictures off their server.
Old Aug 10, 2006 | 06:21 AM
Eyal 951's Avatar
Default Re: My Big Build Thread - D Series Hybrid (Slothy)
I'll fix the pics today. The compression calculator for this specific setup, everything included with the 2 layer, the Y8 head and the overbore hits exactly at 11.0:1 CR.
Old Aug 10, 2006 | 07:12 AM
Natural Aspirations's Avatar
You may wish to clay this motor to check you piston to valve clearance. The valves on the d16y8 head are spread farther apart due to the extra cam lobe than they are on the a6. Should be ok, just a precaution.
Old Aug 10, 2006 | 08:08 AM
Eyal 951's Avatar
Default Re: (EJDan)
hmmm, its actually something that didn't cross my mind. The pistons do sit lower in the cylinder however.
Old Aug 10, 2006 | 08:13 AM
LowSlow93Sol's Avatar
Default Re: (Eyal 951)
Sounds like a good build of the D.
pics no workie
Old Aug 10, 2006 | 08:15 AM
-Gary-'s Avatar
picks nooooo workie.
Old Aug 10, 2006 | 08:19 AM
Paprika's Avatar
I want pictures!!
Old Aug 10, 2006 | 08:29 AM
Eyal 951's Avatar
Default Re: (Paprika)
Pics up!!!
Old Aug 10, 2006 | 08:33 AM
Bulli Kid's Avatar
nice built and i can see the pics
1 question though
why the a6 pistons?
Old Aug 10, 2006 | 08:35 AM
Eyal 951's Avatar
Still have plenty to do on the car. I don't like the wheels, the tint is old, etc etc...
Some things waiting to go on soon:
-Full GSR suspension and brakes between the subframe and body, front and rear, from an '01 with 45K, including 1" master cylinder, and Integra brake booster.
-Rebuilt Manual rack with Quaife Short ratio gear installed.
Old Aug 10, 2006 | 08:36 AM
Eyal 951's Avatar
Default Re: (Bulli Kid)
I was looking for about 11:1 CR, and they got me there. They are also quite flat which I feel is a good attribute in a piston.
Old Aug 10, 2006 | 08:53 AM
spooncivic1's Avatar
so how are you using 75mm pistons in a 76mm bore engine??
Old Aug 10, 2006 | 08:58 AM
Eyal 951's Avatar
Default Re: (spooncivic1)
See the 1.00 on the piston? That means 1mm over... If my math is correct then: 75mm+1mm=76mm
Old Aug 10, 2006 | 09:04 AM
EvilPinkEye's Avatar
nice build
Wanna See Numbers soon
Old Aug 10, 2006 | 09:07 AM
Eyal 951's Avatar
Default Re: (EvilPinkEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye &raquo;</TD></TR><TR><TD CLASS="quote">nice build
Wanna See Numbers soon</TD></TR></TABLE>
So do I!
I'm hoping to swap next week, and first thing i do after getting the rings to seat is professional dyno tuning.
Old Aug 10, 2006 | 09:44 AM
Awesome! Looks great and the 944 sitting next to the hatch is nice too.
