Suspension Just about done..
Old Apr 24, 2002 | 05:09 PM
Nighthawk GS-R's Avatar
New User
Default Suspension Just about done..
Ok i have put on ITR springs, shocks, rear LCA's, rear JDM Chassis bar, and finally just put on the rear R sway bar. What a damn difference. Holy **** is all i can say!! With stock crap tires my car handles like a *****. i havent even reached its limits.
Anyway my question is, is this setup good for autocrossing? or should i get stiffer springs? i dont want the slammed look. i need an inch drop and no more. please bare in mind i no nothing about autoxing. i see alot of the R guys doing but with stock suspension?
Thanks in advance
Old Apr 24, 2002 | 05:17 PM
AcuraRacer112's Avatar
Default Re: Suspension Just about done.. (Nighthawk GS-R)
The set up is fine, have fun....nuff said
(from expierence with others cars namely xjohnx ITR)
Old Apr 24, 2002 | 05:33 PM
New User
Default Re: Suspension Just about done.. (AcuraRacer112)
thanks alot bro....
Old Apr 24, 2002 | 05:57 PM
HondaJon's Avatar
That setup performed nicely enough for Acura to name it TYPE-R, so it should perform well enough for a first time autocrosser for sure. Get a helmet, buckle up, and have fun this auto-x season. You will know when your driving skills have surpassed your suspension setup, and you will NEED something stiffer.
Good Luck,
Jon
Old Apr 24, 2002 | 06:40 PM
owen_the_soyboy's Avatar
Default Re: Suspension Just about done.. (HondaJon)
stock ITR suspension is much more than most ITR owners can master anyhow.
the setup is perfectly balanced for optimum handling... so I wouldnt change out the springs.
even on my GSR sedan the ITR setup was incredible for autox, then I took it to Pocono !
Old Apr 24, 2002 | 07:09 PM
JL 74's Avatar
Damn, you are getting me too excited. That is the exact set up I am working on. All should be on thier way but still looking for that lca.
Old Apr 24, 2002 | 07:15 PM
New User
Default Re: Suspension Just about done.. (jl74)
yeah ur right acura made this suspension setup for a reason..thanks for all the colpiments guys.
btw how do u sign up for autoxing? how does it work whenu do it?
Old Apr 24, 2002 | 07:34 PM
RacingE_Teg's Avatar
Default Re: Suspension Just about done.. (owen_the_soyboy)
The ITR suspension is very good...but when you decide to upgrade, the ITR setup will seem soft.
Old Apr 24, 2002 | 09:08 PM
Integ Grl's Avatar
http://www.scca.org to sign up.
http://www.tirerack.com/features/solo2/handbook.htm ...should give you some useful info for your first day out.
Old Apr 25, 2002 | 04:41 PM
New User
Default Re: Suspension Just about done.. (Integ Grl)
thanks alot guys!! anyone have any negative things to say about this setup?
Old Apr 25, 2002 | 05:13 PM
HondaJon's Avatar
Get some sticky tires and you'll be in like Flynt
HRubss
Apr 25, 2015 04:01 AM
Xymox007
Aug 7, 2007 04:19 PM
Mr. Softee
Jun 26, 2002 03:52 PM
Thrillhouse
Jun 21, 2002 10:04 AM
fiebru1119
Apr 3, 2002 09:09 PM
