Suspension & Brakes Theory, alignment, spring rates....
tein ha ?
Old Aug 9, 2006 | 04:52 PM
jdmef-9's Avatar
Default tein ha ?
well theres a set of tein HA's on ebay going for real cheap only probleme is there for an ef-8.. so my question is will they work on my dc2.. i have itr control arms so im assuming the ef-8 ball style mount is the same as the itr.. and also isnt the ef front strut mount a bit smaller in diameter?
thanks for ur help.
Modified by jdmef-9 at 6:16 PM 8/9/2006
Old Aug 9, 2006 | 04:55 PM
dohcMONSTER's Avatar
Default Re: tein ha ? (jdmef-9)
no they wont
Old Aug 9, 2006 | 05:12 PM
jdmef-9's Avatar
ne one else?
Old Aug 9, 2006 | 05:24 PM
Lan's Avatar
Lan
Default Re: (jdmef-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef-9 &raquo;</TD></TR><TR><TD CLASS="quote">ne one else?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">no they wont</TD></TR></TABLE>
x2
Old Aug 9, 2006 | 05:25 PM
jdmef-9's Avatar
hmm i guess i dont understand why they wouldnt work a friend of mine ran tein felxs for an itr on his crx without any problemes
Old Aug 9, 2006 | 05:26 PM
Lan's Avatar
Lan
The lower control arm is different.
Old Aug 9, 2006 | 05:28 PM
jdmef-9's Avatar
the rear lca...
Old Aug 9, 2006 | 05:29 PM
Lan's Avatar
Lan
Oh ****, I din't see that they were for the fronts. I dunno
Old Aug 9, 2006 | 05:31 PM
jdmef-9's Avatar
well to the best of my knowledge the only issue i would have would be with the front struts bucause the diameter of the mounting hole would be to wide.. i dont c wat the difference is between the itr rear lca and the ef-8 rear lca being that there both ball style
Old Aug 9, 2006 | 05:32 PM
Lan's Avatar
Lan
I dunno, maybe this thread should be moved to the Suspension Forum. Those guys would know for sure
Old Aug 9, 2006 | 05:33 PM
jdmef-9's Avatar
yea ur prolly right my bad
Old Aug 9, 2006 | 05:34 PM
Lan's Avatar
Lan
Want to report it? It can be moved
Old Aug 9, 2006 | 05:35 PM
jdmef-9's Avatar
yea please do
mod please move thread to suspension forum
Old Aug 9, 2006 | 05:36 PM
Lan's Avatar
Lan
Reported for the move
Old Aug 9, 2006 | 06:01 PM
jdmef-9's Avatar
f-it i bid on them ne ways... worse case scenario ill put them on my ef and put my omni's on my dc...
still waiting for an ansewer...
Old Aug 9, 2006 | 06:19 PM
Tyson's Avatar
front lower fork is different, yes smaller diameter. the fork is interchangeable so you could get a ef/da one.
the rear lca is almost identical to the itr as well. so youd need that too.
Old Aug 9, 2006 | 06:23 PM
jdmef-9's Avatar
i already have itr lca's so ur saying all i will need is the ef front shock mount
Tyson's Avatar
what was i not clear about?
Old Aug 9, 2006 | 06:25 PM
jdmef-9's Avatar
u weren't clear as to whether i would need the 88 lca's or the itr lca's all u said is that they are similar
Old Aug 9, 2006 | 06:26 PM
Tyson's Avatar
youll be fine with the itr lca.
Old Aug 9, 2006 | 06:27 PM
jdmef-9's Avatar
thanks thats all i needed to know
Old Aug 11, 2006 | 05:32 AM
Moto-hashiriya's Avatar
I don' t know about US spec vs JDM spec but from past experience with JDM spec DA/EF/EG/DC suspension:
For the front you can use the shocks if you use the appropriate fork.
EX. EG/DC front shocks with EG/DC forks will fit EF/DA
For the rear, DA/EF are a little narrorer on the metal collar that is in the bushing on the bottom mount point.
EX. EF/DA rear shocks onto EG/DC you add a washer or 2 to get rid of play. For EG/DC rear shocks onto EF/DA, you may have to shave/grind down the metal collar/tube(?) about an 1/8".
Sometimes this collar/tube can be replaced depending on manufacturer on the shocks with the appropriate length needed.
In general. EG/DC shocks are longer in stroke VS DA/EFs so putting EF shocks on an EG/DC will "slam" it nicely.
If any of the above is wrong please correct me. I hope this helps.
Old Aug 11, 2006 | 08:10 AM
Tyson's Avatar
Default Re: (Moto-hashiriya)
i dont think theres an issue with the bushing width in the rear. the EK's are the ones with thinner bushing width. EF/DA and EG/DC are the same from my experience.
Old Aug 11, 2006 | 08:45 AM
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i dont think theres an issue with the bushing width in the rear. the EK's are the ones with thinner bushing width. EF/DA and EG/DC are the same from my experience.</TD></TR></TABLE>
EKs don't mount like JDM DA/EF/EG/DCs in the rear. They don't have bushings in the shock but on the LCAs right?
Old Aug 11, 2006 | 08:46 AM
Tyson's Avatar
ah, right, youre talking about jdm ball type end. nvm.
hmm.. interesting to hear that EK's dont have the normal JDM shocks. thanks.
so then i gather from what youre saying ,the difference between 88 CRX (like all jdm ef) and our ITR (like all jdm dc) is about 1/8" width around the bushing. more interesting info.
