rear toe
Old Aug 9, 2006 | 03:35 PM
Craigp23usa's Avatar
Default rear toe
i have a 91 civic with rear trailing arms etc for disc brakes from a da integra. i just got an allignment and they said they need more adjustment.
i still have to much toe out.
i have a camber kit and the rear is set to .2 degrees.
i asked him to but it at 1.5
if he changes it to the 1.5 will it make it make my toe better.
if not.....what the hell should i do. get the toe adjuster?
over all it is about -1.21 degrees out total. Each wheel is out so i know there is a small posibility of them both being bent.
Old Aug 9, 2006 | 03:44 PM
brg2nr's Avatar
Camber and Toe are NOT related.
Which lower control arm did you use? I would suggest that it may be that the Integra one is too long... I have not done this swap in a long time, I wish I could remember more...
Anyone else?
Old Aug 9, 2006 | 06:43 PM
jdm_ef9_b16's Avatar
try putting your stock ones back on and see what happens. but i think u need the stock ones. lemme know . im about to do this swap. been a while since i helped do one. later
Old Aug 9, 2006 | 07:00 PM
i know that u need the stock ones but the problem is i did not do the swap and im wondering witch ones the guy before me used. he prob. used the teg ones but should have used the ciic ones. thats what i hope it is so that i can fix my prob easily.
Old Aug 9, 2006 | 07:10 PM
Crx Jimmy's Avatar
Default Re: (brg2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brg2nr &raquo;</TD></TR><TR><TD CLASS="quote">Camber and Toe are NOT related. </TD></TR></TABLE>
They ARE related. Who told you that that? it is not true. when you lower a car and the camber decreases( negative camber) the toe out increases,
and just get some toe adjusters , I have them you can dial the toe in much easier and they can compensate by getting shorter or longer than stock
Old Aug 9, 2006 | 07:15 PM
thanks for the updat i thought that it would because of the so many diff radius's of the arms.
what adjustable one did you get? where did u get it and do u think i can pick one up somewhere before fri afternoon. honda day is coming up way to fast?
chris riz
Jun 25, 2011 07:21 PM
JDMchucko
11
Oct 25, 2010 04:43 PM
RED EK NJ
Suspension & Brakes
Mar 27, 2005 12:58 PM
dng
May 25, 2004 07:29 AM
91SIR
Apr 22, 2003 01:56 PM
