turn signals r not working
ok the back one on the driver side works but nothin else if u hit the hazard button all the signals flash but the front driver side. i could be the switch, but don't know. maybe a relay don't know if there is a relay for the signals. i don't think fuses why would they make a right and left signal fuse. i really could use a pic of the wiring on the 2 front corner lenses. bulbs are not blown i checked that already.
so less review the back driver side is the only signal that works if u hit the switch to go right nothin no clicking.
please help.\
thanks
please help.\
thanks
Yo, I would say check or replace your bulbs. If one of them isn't working correctly then the others don't work. Wouldn't be a bad idea to check all the fusses too.
well i got the signals to work but the front drivers side still isn't working. bulbs are fine i put power to them and they worked prefect. but the wires not getting any juice. to that one corner lense.
I have the same problem all my turn sgnals work except for the pax side corner turn signal - its not getting any juice either but the parking light on the pax side corner worx - I have been putting it off trying to figure out where the problem is
- keep us updated with what you find out
chris riz
Oct 12, 2011 04:33 PM
