Dyno charts of stock ITR's
Old Apr 24, 2002 | 04:40 PM
Reelizmpro's Avatar
Default Dyno charts of stock ITR's
Anyone ever dyno their ITR? or know how much front wheel HP/torque they actually put out?
Old Apr 24, 2002 | 04:45 PM
sxgt's Avatar
Default Re: Dyno charts of stock ITR's (Reelizmpro)
http://b16a.com/dynocenter/home.html
Should be able to find a few stock itrs.
Old Apr 24, 2002 | 04:48 PM
Rob :190:'s Avatar
stock ITRs usually put down high 150s to low 160s.
Old Apr 25, 2002 | 01:13 PM
Ryuji's Avatar
New User
Default Re: Dyno charts of stock ITR's (Brian Spilner 1035)
Look at my signature... Euro ITR
Not bone stock but nearly...
Old Apr 25, 2002 | 10:33 PM
Art Vandeleigh's Avatar
Default Re: Dyno charts of stock ITR's (Ryuji)
here is mine.
this is bone stock.
[Modified by cali-r, 7:34 AM 4/26/2002]
Old Apr 25, 2002 | 11:22 PM
Hacemuy's Avatar
Default Re: Dyno charts of stock ITR's (cali-r)
Don't different dynos put down different numbers? I thought that dynojet was highest while mustang was lower...
Are there any good dynos in Oregon?
Old Apr 25, 2002 | 11:46 PM
YelLowITR's Avatar
mine car bone stock dyno 163, so it's pretty much the same except the curve smoother than other i have seen. Also i know there is a stupid way some ppl dyno is they let the car free run and uses something to stop front wheels and this way really gives you a BIG different number but i don't think it's correct tho .
Old Apr 26, 2002 | 05:11 AM
01ITR#700's Avatar
Default Re: Dyno charts of stock ITR's (YelLowITR)
Here is mine. The car is Bone stock and had approx. 3500 miles on it at the time. The higher #'s are from 3rd gear, the lower run was in 4th gear.
M
Old Apr 26, 2002 | 05:25 AM
SwiftTypeR's Avatar
New User
Default Re: Dyno charts of stock ITR's (01ITR#700)
i got 163 whp sae in 4th gear stock.
Old Apr 26, 2002 | 05:27 AM
Dr Pooface's Avatar
Default Re: Dyno charts of stock ITR's (SwiftTypeR)
I got 168/120 stock.
Old Apr 26, 2002 | 06:04 AM
ITR764's Avatar
Default Re: Dyno charts of stock ITR's (George Knighton)
4th gear pull, 162.8/114.5 bone stock.
Old Apr 26, 2002 | 08:24 AM
type r 01-1063's Avatar
do you guys know how much it generally cost to get your car dynoed?
Old Apr 26, 2002 | 08:57 AM
comptechgsr2000
Guest
Posts: n/a
Default Re: Dyno charts of stock ITR's (type r 01-1063)
I have friends that type R's and its anywhere from 158-165hp. With i/h/e I've seen 170-173hp
Old Apr 26, 2002 | 09:06 AM
Sam's Avatar
Sam
Default Advance timing vs stock timing
So, I saw a 97 bone stock ITR with advance timing to 17.5 degree gain 4 hp to the wheel which made me want to advance my 97 ITR timing also, anyone done this? And anyone know how to? And it also mention that 97 ITR with the same advance timing do not show gain in high rpm but midrange, why? Anyone can explain?
Thanks.
Old Apr 26, 2002 | 09:57 AM
AssPenny's Avatar
Default Re: Advance timing vs stock timing (C5_ALLMOTOR)
Bone stock, 10,000 miles. One was stock timing, other was timing set to 16deg.
Old Apr 26, 2002 | 09:59 AM
sackdz's Avatar
Default Re: Advance timing vs stock timing (AssPenny)
Stock with no power steering, Mustang Dyno. The force is strong with this one
[Modified by sackdz, 2:01 PM 4/26/2002]
mac_24_seven
17
Oct 19, 2007 03:51 PM
B18CXr
Apr 17, 2005 07:15 PM
89 JDM CRX
Jun 8, 2004 03:23 PM
Junglist
May 6, 2002 09:06 PM
YellowSpeed
Feb 27, 2002 04:40 AM
