Alignment was no help...still have positive camber
Old Apr 24, 2002 | 04:10 PM
Type R1's Avatar
Default Alignment was no help...still have positive camber
I took the advice of those who told me to go for an alignment to try to fix my wheels positive camber. Well it didn't work.
any one else have any other suggestions. Or am i stuck with the positive camber.
oh, by the way, car has stock suspension
thanks
Old Apr 24, 2002 | 04:12 PM
Reid's Avatar
Global Moderator
Default Re: Alignment was no help...still have positive camber (Type R1)
Your suspension arms must be bent. There's no way you can have positive camber without bent suspension pieces. If possible compare your suspension pieces to one off another ITR.
Old Apr 24, 2002 | 04:19 PM
Cheap Bastard's Avatar
New User
I have never heard of this problem. That's weird. Get new adjustable upper control arms.
CB
Old Apr 24, 2002 | 05:04 PM
Ricky Rojales's Avatar
I didn't read your original post so disregard if my suggestions are redudant:
How' bout your lower LCA or knuckle/hub/spindle assembly being bent? Match it up to one that you know is OK.
If none of that works have your chasis alignment checked... it would suck if that's the case though.
Old Apr 24, 2002 | 05:05 PM
t's Avatar
t
thanks
lower your car
Old Apr 24, 2002 | 05:14 PM
R R's Avatar
R R
Default Re: Alignment was no help...still have positive camber (t)
i have no prob for mine..got ingalls front/rear camber installed..everything went fine...everything close to oem spec
HondaCivic2006
Honda Civic (2006 - 2015)
Mar 19, 2009 04:40 AM
Blamm!!
Apr 7, 2008 04:34 AM
Greyout
18
Aug 4, 2004 12:47 PM
ThaSpitefulWun
Sep 23, 2002 01:56 PM
