need help with wiring
Old Aug 9, 2006 | 10:53 AM
fastguy8's Avatar
Default need help with wiring
i would like to rewire my complete wire harness on my 89 dx im putting a b16a in it but dont know how to rewire any help
Old Aug 9, 2006 | 10:55 AM
anek's Avatar
Default Re: need help with wiring (fastguy8)
order a harness.
Old Aug 9, 2006 | 11:01 AM
Loserkidwac's Avatar
Default Re: need help with wiring (anek)
Well I would start by doing an mpfi conversion first, just do a search and you will find tons of info on what needs to be done, and then to upgrade from there for the b16 you will just need to wire in the knock sensor and vtec...start small and work your way up, get the mpfi done first so when you do the swap and it won't start you don't have 8 million wires to go through
fastguy8's Avatar
wat kind of harness
Old Aug 9, 2006 | 11:03 AM
fastguy8's Avatar
Default Re: need help with wiring (Loserkidwac)
wat a mpfi and were can i get it from
Old Aug 9, 2006 | 12:01 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
To install a B-16,
You need to convert the injector wiring from "Dual-point fuel injection"
to "Multi-Port fuel injection.." known as a DPFI to MPFI conversion.
What that means is instead of a throttle-body with two injectors,
You use a single injector for each cylinder...
See: http://crf50.no-ip.com/fourthgenhatch/mpfi.html
for an example and more detailed description...
To do this,you will need an injector resistor box and its wiring,
four injector clips and some harness plugs that can usually be sourced from the B16..
Also See the FAQ at the top of this section..
KraziCivicSi
Nov 9, 2006 11:35 AM
ivanson
Nov 5, 2005 06:00 PM
ThatsMyEG
Feb 12, 2005 02:21 PM
LSvtechatch97
Oct 15, 2004 04:30 AM
chadmasterc
Jul 9, 2003 07:43 AM
