EP3 5-lug conversion
Old Aug 9, 2006 | 10:51 AM
ErniePower_3's Avatar
Default EP3 5-lug conversion
i am going to change to 5-lug on my ep
is it still using ep3 shocks/coilovers or dc5 ones after dc5 knuckle installed
thanks
Modified by ErniePower_3 at 12:28 PM 8/9/2006
Old Aug 9, 2006 | 02:03 PM
whiteDCfiver's Avatar
Default Re: EP3 5-lug conversion (ErniePower_3)
You'll still use ur struts and springs
Old Aug 9, 2006 | 03:04 PM
Default Re: EP3 5-lug conversion (whiteDCfiver)
really?
thanks
but is that possible i can use dc5 coilovers?
since the good quality coilover only make for dc5
Old Aug 9, 2006 | 05:55 PM
spring rates are all different.
Old Aug 9, 2006 | 07:30 PM
97 TYPE-R 312's Avatar
FYI.. the DC5 rear LCA is just a bit different than the EP3 LCA. The DC5 LCA has a wider opening for where the rear shock sits into the LCA. So if you do use that DC5 LCA, then it <U>would</U> be better to use the rear DC5 shock assembly. If you use your EP3 LCA, then use the EP3 shock assembly.
-Victor
Old Aug 9, 2006 | 10:00 PM
Default Re: EP3 5-lug conversion (97 TYPE-R 312)
hey Victor
do you have dc5r brembo on your ep?
i have a set of dc5r brembo too,
you must change to 5-lug to get it fits right?
what pads you are running on your brembo?
and one more thing
is that possible to use the rsx coilovers (i found a used apexi n1 damper really cheap), i heard you need to mod it fit, isn't it?
i know there are lots of questions, but thanks anyways
Old Aug 10, 2006 | 07:44 PM
Yes, I have that setup on my EP3. You have to change it to the 5lug hub. I'm running stock pads, but have 350Z pads for the next run. You should run RSX coilovers in the rear (at least) to fit right. If not run EP3 coilovers with washers in the rear to prevent movement within the LCA.
-Victor
Old Aug 10, 2006 | 09:43 PM
thanks man
i just got my dc5 apexi n1 damper today
i hope this is gonna work
can't wait to put it in
Old Aug 11, 2006 | 11:53 AM
Default Re: EP3 5-lug conversion (blackdc5)
yes
pr0j3xt01v1c
Honda Civic (2001 - 2005)
14
Mar 1, 2008 06:19 PM
dohdoh420
18
Nov 10, 2005 12:30 AM
Shingo
Suspension & Brakes
Aug 14, 2005 10:28 PM
justininhifi
Apr 30, 2003 12:25 AM
