91 integra wont start help!!!
Old Aug 9, 2006 | 10:32 AM
neodre's Avatar
Default 91 integra wont start help!!!
The car started perfectly in the morning, now it jus turns over and nothing. I kept trying until the battery died! I need some help
Old Aug 9, 2006 | 11:44 AM
90dateg's Avatar
Default Re: 91 integra wont start help!!! (neodre)
your main relay sounds like it died-
Old Aug 9, 2006 | 01:22 PM
96 EJ8's Avatar
Default Re: 91 integra wont start help!!! (90dateg)
sounds like your main relay is fried, get it checked out acura dealer sells it for roughly $60 but dont quote me on that and while your doing that check if your car engine is getting fuel
Old Aug 9, 2006 | 01:50 PM
cleanda6's Avatar
chekc if u have spark and fuel
also chekc under ur dizzy cap to see if ur rotor got loose
Old Aug 9, 2006 | 02:08 PM
lVlemphizStylez's Avatar
Default Re: (cleanda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanda6 &raquo;</TD></TR><TR><TD CLASS="quote">chekc if u have spark and fuel
also chekc under ur dizzy cap to see if ur rotor got loose </TD></TR></TABLE>
id start here before you buy any main relay
Old Aug 9, 2006 | 06:17 PM
lhd dc2's Avatar
Default Re: (lVlemphizStylez)
It might be your main relay. It tends to happen when its hot outside and when it gets old and the solder cracks. I have the same problem sometimes after sudden stop and having to recrank the car or first start when its real hot outside. All I do is bang on the left side of the panel where the main relay is and it works. It might work for you.
another thing...does your check engine light come on? do you hear fuel pump prime?
Old Aug 10, 2006 | 01:58 PM
neodre's Avatar
Default Re: (lhd dc2)
yea the check light came on then fade out. when i tried starting it kinda sound like when ur engine chokes
EF9_RIDER37
20
Jun 8, 2010 11:29 AM
redcivic13
Sep 29, 2008 08:50 PM
H22Ej1
Jun 14, 2007 09:30 PM
bigbacon2
Sep 17, 2005 03:41 PM
livelife46290
Aug 26, 2004 07:07 PM
