head porting = 320+cfm...
I want to see a real flow chart of that. I have only seen 1 that high and it was mine at 314, then we had to do some minor changes to get it down to 308 to get beck some mid lift flow points..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG type GTR »</TD></TR><TR><TD CLASS="quote">is there even a way to take full advantage of that kind of head flow on a all motor street b series while still using pump 93?</TD></TR></TABLE>
Yes! Put it on my street motor
And post the flowchart for all to see!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">I'll pay for the flowsheet to be posted.</TD></TR></TABLE>
trying to get it from the builder... stay tuned...
Well its probably a square port head..Which may flow alot of peak # but the flow curve will probably suck.. Its just like a dyno plot , the peak doesnt mean much and its the overall curve.
But heck if its 320 with a good curve then more power to them..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Well its probably a square port head..Which may flow alot of peak # but the flow curve will probably suck.. Its just like a dyno plot , the peak doesnt mean much and its the overall curve.
But heck if its 320 with a good curve then more power to them..</TD></TR></TABLE>I was about to say the same thing.Ive done some testing with square ports and have gotten 335 with a 35 mm valve but the port is WAY to big to use on anything i could think would fit within a b series case.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">second youd want a bottom end that can stand high RPM abuse. The compression wont matter TOO much, because at that RPM, dynamic>static.</TD></TR></TABLE>
and i just happen to have one of those bottom ends for sale
Curbow_USMC
27
Sep 27, 2005 04:04 AM
Stock@$$GSR
Oct 18, 2004 06:51 PM
prob 320cfn @550 lift @30k ft vac
