Guys with autometer a/f guage
How many of you guys are using them? Do you get a range of about 4 to 5 lights being lit as the display goes from left to right? If you are then something is not right and we need to work together to fix this. It's a common problem with hondas and I see other hondas here with the same problem and I'm convinced it affects performance. The computer is basically seeing this (blurr) change in readings and trying to compensate accordingly. I already change my O2 sensor same problem. I also change my guage thinking it was bad. Is this happening to any of you guys? When I first installed the guage it lit up one led at a time and the car ran perfect
Now even at full throttle I get about 4-5 leds on in the rich area. We really need to solve this.
From my understanding the stock o2 sensor (narrow band) only reads lean or rich, and nothing inbetween.. which is why you get about 5 LEDs jumping from lean to rich, and why you'll never get an accurate reading (1 LED or so). This is also why most people claim a/f gauges are good for nothing more then a very rough idea of how your engine is running (ie, if it's always on lean.. that's bad).. and why a wideband o2 sensor/gauge is higly recommended..
someone correct me if i'm wrong..
