need help with rings
Old Aug 9, 2006 | 08:22 AM
drewjesterjcc's Avatar
Default need help with rings
here my problem. i have these rings that are 84mm and the rings are .014 of an in. but i need them to be .08 of and in. and will this make u car run like **** if i just left it the way it is. or were can i find rings. that i can fiel fit
Old Aug 9, 2006 | 08:44 AM
nvmyb20hatch's Avatar
Default Re: need help with rings (drewjesterjcc)
where did you get specs for a ring gap of .08''? thats crazy tight
Old Aug 9, 2006 | 09:26 AM
Runnerdown's Avatar
What kind of pistons? whats the motor setup. I am local and may be able to help out.
Old Aug 9, 2006 | 02:16 PM
akura404's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmyb20hatch &raquo;</TD></TR><TR><TD CLASS="quote">where did you get specs for a ring gap of .08''? thats crazy tight</TD></TR></TABLE>
You're probably thinking about .008". Eighty thousandths (.080) is crazy wide for a ring gap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewjesterjcc &raquo;</TD></TR><TR><TD CLASS="quote">here my problem. i have these rings that are 84mm and the rings are .014 of an in. but i need them to be .08 of and in. and will this make u car run like **** if i just left it the way it is. or were can i find rings. that i can fiel fit</TD></TR></TABLE>
.080" is crazy wide. What are you thinking? Do you mean .008"? If yes, then nvmyb20hatch is right....that's crazy tight!! We need more info from you. I'm assuming your NA since you posted on this forum. What's your compression? This plays a big role in Ring Gap. Too tight and your ring will overlap....this means you'll be in deep ****. Too wide and you will have bad sealing and blowbys. Again, more info is needed.
Which ring gave you .014",...top, second, or oil ring?
pornstar4777
Feb 14, 2008 12:47 PM
boostincoupe
Apr 10, 2006 01:19 PM
aser1z
Sep 12, 2005 08:57 PM
turbodohcsi
Jan 1, 2005 10:22 AM
hondaguyef
Jul 8, 2004 02:51 AM
