Spark plug heat ranges???
Old Apr 24, 2002 | 03:45 PM
DelsolVtec18's Avatar
New User
Default Spark plug heat ranges???
What does it mean to drop 1 heat range on the spark plugs ...Is that 1 heat range hotter or colder??? What is the heat range on ngk spark plugs for the B18C from the factory???
Old Apr 24, 2002 | 06:35 PM
m0t0rhead's Avatar
Default Re: Spark plug heat ranges??? (DelsolVtec18)
You're probably talking about 1-step colder plugs. They're generally good for a couple more HP and allow the heat to transfer better for lower engine temperatures.
Old Apr 24, 2002 | 06:41 PM
rainforest's Avatar
Default Re: Spark plug heat ranges??? (Escobar)
esco is right.
Old Apr 24, 2002 | 07:52 PM
BSQ's Avatar
BSQ
Default Re: Spark plug heat ranges??? (rainforest)
Go to http://www.ngksparkplugs.com/techinf...overviewp2.asp for some good information on spark plug heat ranges.
Old Apr 27, 2002 | 08:18 AM
m0t0rhead's Avatar
I think from the factory they're 5's.
I run 6's
KloC 95 EG
28
Feb 2, 2009 12:35 AM
zakiu
Honda S2000
17
Apr 23, 2007 09:04 AM
pa2play
Jul 25, 2004 01:15 PM
Hoodwinked
Oct 24, 2003 08:45 AM
