Help with 00 Si no spark dizzy problem
Well here's my story, the car had a new harness from honda put in and got rid of some problems but one still persists, which is the one sensor in the dizzy, ok fine so we bought a dizzy and than we put that on and that didn't start the car, so we said fine we'll just put the old one back in and we'll have to drive it like that for a while and figure it out later, but now that we put the old one back on it doesn't start.....so at this point I was like wtf. We have 3 dizzy's total, 1 new one, and one from the original car, and one from someone we bought it off of here. I checked for spark and there is nothing, I checked the harness plug connection to the dizzy and thats getting power, so since we have so many parts for the dizzy I decided to swap parts on the dizzy's still nothing. We even went to go buy another brand new coil and that still doesn't do anything for it. Thanks.
PS. It cranks over everytime.
This is the same damn problem with my car! I've replaced the i.c.m. the coil, the main relay and still nothing, so i'm going to try a different ecu. Have you guys tried different ecu's?
u said u change ur harness rite, u sure u getting a good ground and its the ground bolted down . same stuff happen to a friend of mine. 1 ground wire wasnt bolted down. and make sure u getting a good ground
we replaced the ignitor 3 times, it's getting spark to the actual distributor........ should I still check the ignition switch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michler »</TD></TR><TR><TD CLASS="quote">I'm gonna try switchin ecus also, I'll post if it works or not... thanks for the help</TD></TR></TABLE>
well if anyone cares, I switched ecus and that was the main problem
hope that helps someone else
mikkey1
Sep 3, 2008 11:46 AM
gxiang
Apr 30, 2007 06:50 AM
almighty
May 5, 2004 04:53 PM
