integra brake booster and mc on eg
Old Aug 9, 2006 | 01:00 AM
lv6l's Avatar
Default integra brake booster and mc on eg
i have a 94 civic hatch cx. i had problem either with my mc or my brake booster; whenever i step on the pedal it would slowly starts to sink. i have tried bleeding it many times and i was thinking my mc is messed up and time for a new one. i been holding it off and now that i have turbo running on it and using the vacuumm line i'm losing pressure and the problem is getting wrose, the brake pedal feels weak, doesn't feel like i can even lock the wheels if i push it hard and fast. i was wondering is there any booster and mc out there i can use that will fit with NO mod. and will give me a shorter pedal(i have to step mine pretty deep to feel stopness) if there is none out there that will fit what are my other alternatives and is there a DIY. thank you.
Old Aug 9, 2006 | 04:37 AM
sohc1200cc's Avatar
bolt-on!
Old Aug 9, 2006 | 10:01 AM
lv6l's Avatar
Old Aug 9, 2006 | 10:25 AM
NonovUrbizniz's Avatar
Loved
Default Re: integra brake booster and mc on eg (lv6l)
A TON will fit.
Your original prob. is almost definatley a leaky seal in the Master.
Then with going turbo the vacum assist in the brake booster deminishes...
Anyway... you can use a 15/16ths master AND booster from 90-00 integra... you have to swap them as a pair since the bolt pattern is reversed for the integra.
OR you can get JUST a master from some weird year civic... it's in the big brake thread that's stickied at the top of this forum.
Old Aug 9, 2006 | 10:28 AM
lv6l's Avatar
oh i see. and the brake lines will all line up? and i need one that is non abs correct?
Old Aug 9, 2006 | 11:54 AM
Loved
Default Re: (lv6l)
Yeah... the brake lines all line up to the 15/16ths master... NOT the 1" ITR master.
I couldn't find that brake thread and it's not stickied any more... I think it was called "Can I put X brakes on Y car" or something like that...
Old Aug 9, 2006 | 12:05 PM
lv6l's Avatar
oh i see. thanks. what does the 15/16 mean
also will a 90-93 integra non abs booster and mc work on my 94 civic cx hatch?
Modified by lv6l at 1:18 PM 8/9/2006
Old Aug 9, 2006 | 12:58 PM
deathplaza's Avatar
Default Re: (lv6l)
15/16 is the size of the master cyl. bore, that is the one for rear disc brake civics and integras, if you have drum brakes still that would not be the correct one. if you still have drum brakes i would suggest doing the booster/MC/proportioning valve, and rear disc brake conversion, although thats expensive. maybe an integra MC would help on a drum car but im not sure about that, it seems like it would cause unequal braking.
Old Aug 9, 2006 | 01:02 PM
lv6l's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 10, 2006 | 09:02 AM
Loved
Default Re: (lv6l)
That's what I have on mine. So yup... but remember its gotta be the booster and master.
Old Aug 10, 2006 | 09:04 AM
Loved
Default Re: (deathplaza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deathplaza &raquo;</TD></TR><TR><TD CLASS="quote">15/16 is the size of the master cyl. bore, that is the one for rear disc brake civics and integras, if you have drum brakes still that would not be the correct one. if you still have drum brakes i would suggest doing the booster/MC/proportioning valve, and rear disc brake conversion, although thats expensive. maybe an integra MC would help on a drum car but im not sure about that, it seems like it would cause unequal braking. </TD></TR></TABLE>
FYI... the size of the cylinder just dictates how much pressure it exerts... you could use a 1" master on a car with 4 wheel drums...
You CERTAINLY don't have to do a rear-disk conversion to change a master.
Old Aug 10, 2006 | 09:11 AM
philosofy1's Avatar
if your looking for a larger M/C with no mods, then you will need the M/C (15/16) from a 91 civic ex. will bolt straight to your booster.
here's a whole thread on it:
https://honda-tech.com/zerothread?id=364783
spoon978
Jun 10, 2008 07:34 PM
kajay1972
Sep 5, 2007 07:16 PM
