DIY: Citylights on 94-00 Integra USDM headlights
Old Aug 8, 2006 | 11:51 PM
tyco's Avatar
Default DIY: Citylights on 94-00 Integra USDM headlights
I've been pm' alot about how I did my city lights on my USDM integra headlights on a 94-00 model. So I decided to share my ideas to my fellow honda-tech members with 94-00 Integra with USDM headlights.
Materials:
~194A Stanley Sockets prt#34304-SH3-AO1
~Female Connectors
~Electrical Tape
~Crimps for wires
~194A bulbs (yellow, amber, clear, doesnt matter what color all up to you)
~10mm socket
~Phillip Screw driver
~Electric drill
~Drillmill sander size of the circumfrence of socket
~Masking Tape
~Metal Nibbler
~14G Wires
~Butterfly connectors
Instructions:
~Step 1: First take out the two screws on the corner of the bumper connected to the bumper and take the top screws on the metal plate on top of the bumper.
~Step 2: remove the 2 10mm bolts on the bottom of the bumper and top of bumper on radiator support.
~Step 3: Take a phillip screw driver and remove the screws on the signal corners and remove lights, then take 10mm socket and remove the 4 bolts holding down the head light.
~Step 4: Clean headlight and take a masking tape and place on bottom of the highbeam light housing and mark 1-1/2 inch to mark the whole.
~Step 5: Take a 1/8 drill bit and drill straight through highbeam headlight housing.
~Step 6: Trace the 194 socket on the tape make sure its in the middle of the hole you made with the drill.
~Step 7: Drill inside the traced circle and make sure you drill to the chrome housing as well, be very careful.
~Step 8: Now once you have made that hole, take a drillmill and drill through to make a smooth looking hole for the socket.
~Step 9: On the socket, there are three pieces around it to fit like a key, you are going to take a metal nibbler and cut 3 spaces for the socket to fit in correctly.
~Step 10: Make sure the socket fits if not sand it down with the drillmill.
~Step 11: Take two female connectors and crimp the wires on them.
~Step 12: Locate the 1157 socket, there is a red and black connection, take two butterly connectors and connect one wire to the red connection and clamp it with the butterfly connector and clamp the other butterfly connector with the other wire onto the black wire. Some like to connect it to a toggle switch but its up to you.
~Step 13: Put everything back together and make sure everything is working perfectly.
~Step 14: Wait till the sun is down and enjoy!
GOOD LUCK!
Heres how it looks like completed
Hope you guys like it
Old Aug 9, 2006 | 03:54 AM
jdmOPTION2's Avatar
nice write up. looks good
Old Aug 9, 2006 | 10:51 AM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: (jdmOPTION2)
kinda confusing, but looks great
Old Aug 9, 2006 | 10:53 AM
rino924's Avatar
Community Builder
Default Re: (rino924)
you still have your normal highbeams, correct?
Old Aug 9, 2006 | 04:57 PM
tyco's Avatar
yeap
Old Aug 9, 2006 | 06:27 PM
02_IT-S's Avatar
Default Re: (tyco)
cool, kinda how me and my friend did our ours! now everyone is doing it though! i made a thread about my diy city lights a couple years ago, but never got around to doing a write up.
Old Aug 9, 2006 | 09:07 PM
XplodeTeg's Avatar
i dont think mine isnt as bright. i used the regular clear 194 bulb. now i got particles in my housing n stuck on lens. im gonna try to vacuum tomorrow.
Old Aug 9, 2006 | 09:30 PM
calxtreme's Avatar
nice write up.
Old Aug 9, 2006 | 09:47 PM
tyco's Avatar
yeap, glad everyone enjoys this thread, looking for more city lights on usdm fronts in the future!
Old Aug 9, 2006 | 11:00 PM
Freshazzburu's Avatar
Default Re: (tyco)
What about wiring the bottom turn signals to use as running lights? Would all that have to be done is take the wires and instead of having them connected to the switch for the lights, connect them to the ignition like how the clock is set?
Old Aug 10, 2006 | 12:30 AM
Fat Chick Magnet's Avatar
Old Aug 12, 2006 | 02:08 PM
Default Re:
no one?
Old Aug 13, 2006 | 10:40 PM
tyco's Avatar
Default Re: Re: (Freshazzburu)
I've done it to the clock, just to much wires being run into the bay, looks nasty
Old Aug 14, 2006 | 01:04 AM
shyboi4u's Avatar
Default Re: DIY: Citylights on 94-00 Integra USDM headlights (tyco)
wow, three threads. this one and 2 other.
https://honda-tech.com/zerothread?id=1716378
https://honda-tech.com/zerothread?id=1716374
Old Aug 14, 2006 | 05:45 PM
Default Re: Re: (tyco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyco &raquo;</TD></TR><TR><TD CLASS="quote">I've done it to the clock, just to much wires being run into the bay, looks nasty</TD></TR></TABLE>
I didn't specifically mean to the clock, I meant in a similar fashion. So i'm taking it can be done that way? I've always wanted to have my corners as my daily running lights but never looked into it very much.
Old Feb 19, 2007 | 12:51 PM
ivicr's Avatar
are these the same sockets that are used for sidemarkers ?
Old Feb 19, 2007 | 02:49 PM
GSRfromdaBAY's Avatar
Default Re: DIY: Citylights on 94-00 Integra USDM headlights (ivicr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivicr &raquo;</TD></TR><TR><TD CLASS="quote">are these the same sockets that are used for sidemarkers ?</TD></TR></TABLE>
yup
Old Feb 19, 2007 | 10:27 PM
tyco's Avatar
Default Re: DIY: Citylights on 94-00 Integra USDM headlights (integra420167)
damn this is still going! hahaha
Old Feb 25, 2007 | 11:00 PM
krytoi's Avatar
its like the 3rd tread https://honda-tech.com/zerothread/1716378
Old Feb 27, 2007 | 03:02 PM
tyco's Avatar
Default Re: (krytoi)
hahahaha that thread is still alive!? bump that thread!
Old Feb 28, 2007 | 01:32 PM
Jimmii's Avatar
bump for awesomeness good write up man
Old Feb 28, 2007 | 05:14 PM
tyco's Avatar
Default Re: (LFA Squad: Jimmii)
thank you jimmi of the LFA squad!
Old Feb 28, 2007 | 05:18 PM
gsrswapd's Avatar
bookmarked!
great job!
Old Mar 1, 2007 | 10:40 AM
Jimmii's Avatar
Default Re: (tyco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyco &raquo;</TD></TR><TR><TD CLASS="quote">thank you jimmi of the LFA squad!</TD></TR></TABLE>
np.... see you at the eibach caravan
Old Mar 1, 2007 | 02:18 PM
tyco's Avatar
I will see you there as well man<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LFA Squad: Jimmii &raquo;</TD></TR><TR><TD CLASS="quote">
np.... see you at the eibach caravan </TD></TR></TABLE>
