Is this motor tuned dangerously?
Old Aug 8, 2006 | 10:31 PM
itr1244's Avatar
Default Is this motor tuned dangerously?
Click here to watch "itr-dyno-pull"
Mod list
2001 B18C5
CTR pistons (12.5 ish CR)
RM M22XX
GE camgears (0,0)
RM Ti retainers, dual valve springs.
AEBS IM + IM heatshield gasket
Prototype V'stack with K&N filter.
An-R Standard header with merge collector
Mugen TL. 2.5" all the way
RC 310cc
4.9 FD
excedy organic racing clutch
Fidanaza 7 lbs flywheel
socketed P28 ECU tuned with Crome pro
Vtec X over @ 6100 , Redline 9125
base run.
Final run
Here's the video.
http://media.putfile.com/itr-dyno-pull
link doesnt work?
they let the throttle off at 8000 rpm and just broke my goal which was 200 whp . by .8 whp LOL
what do you guy think about the smoke from my exh? is this bad ?
and the a/f ratio??
any comments welcome
Modified by itr1244 at 2:43 AM 8/9/2006
Modified by itr1244 at 2:46 AM 8/9/2006
Old Aug 8, 2006 | 10:38 PM
Combustion Contraption's Avatar
Air fuel looks to be pretty flat in the 13-13.5:1 area, thats safe enough depending on ignition timing. EGT's are a good way to measure ignition related problems (if there are any).
No the video does not work for me.
Old Aug 9, 2006 | 01:14 AM
UncleD's Avatar
Default Re: (Combustion Contraption)
Video works for me, and I think the a/f can be tweaked a little more. Keep revvin that thing and make more power!
Old Aug 9, 2006 | 06:00 AM
1750cc's Avatar
Default Re: (clean rice)
afr is fine. decent numbers..
Old Aug 9, 2006 | 07:27 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (1750cc)
It looks pretty good. The AF is about 13 which is pretty good.
wannabar
26
Mar 13, 2009 01:07 PM
itr1244
Aug 13, 2006 03:14 PM
itr1244
Jun 11, 2006 02:17 AM
itr1244
Jun 8, 2006 02:23 PM
BigGreenAuto
Jun 6, 2006 07:22 PM
