need help!! transmission problem
Old Aug 8, 2006 | 09:31 PM
98 coupedelux's Avatar
Default need help!! transmission problem
my problem is when my car is in gear its not moving at all the rpm's go up but the car wont move is that a worn clutch? or could i have knocked it out of place? any with idea's please help
Old Aug 8, 2006 | 09:51 PM
RCautoworks's Avatar
Default Re: need help!! transmission problem (98 coupedelux)
Won't move while in gear ? Crawl under the car to make sure your trans linkages is hooked up, if it is I would say you broke something inside the trans.
Old Aug 9, 2006 | 09:34 AM
Default Re: need help!! transmission problem (90blackcrx)
it was running fine until i hit a big pot hole then all of a sudden it wont move in gear i can put it in 1-5 and reverse and it wont move the rpms go up but that's it.. i checked the axles there not popped out
401RIguy
May 10, 2010 07:53 AM
T3T495GSR
Jan 14, 2006 07:38 AM
Rocks.
Aug 22, 2005 03:12 PM
ntt
Oct 8, 2002 12:10 AM
Jt240
Aug 23, 2002 05:11 PM
