stupid wiring harness help!!!!(DC2 )
Old Aug 8, 2006 | 08:35 PM
sle.simon's Avatar
Default stupid wiring harness help!!!!(DC2 )
so i recently bought an aftermarket headunit for my teg. i also bought with it a tube subwoofer. i have everything hookup and all the wires ran. i had to buy a wire harness for hte headunit and wired it all up i then plugged the head unit in my PRELUDE and used it fors couple days with no worries. then today i decide to get the teg working and hooked up the wiere harness ot the teg's plug. there are NO lights. the Screen doesnt light up and there is no music playing. BUT i am able to eject the CD and put it back in. keep in mind it works fine in the PRelude but in the teg it doesnt do anyhting. what could be the problem?
Old Aug 8, 2006 | 08:47 PM
CarbonizedDX's Avatar
Default Re: stupid wiring harness help!!!!(DC2 ) (sle.simon)
Get a test light and check your Red (ignition) wire for power when the key is in the ON possition.
Old Aug 8, 2006 | 08:51 PM
sle.simon's Avatar
Default Re: stupid wiring harness help!!!!(DC2 ) (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">Get a test light and check your Red (ignition) wire for power when the key is in the ON possition.</TD></TR></TABLE>
well if i'm able to still eject the cd and put it in doesnt that mean there is power going to the headunit?
Old Aug 9, 2006 | 12:50 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Proper way is to get a digtal voltage meter to read your accessory wire. Most headunits you can still eject cds while the car is off. Your car can be on but if the fuse is blown on the accessory wire the radio thinks the car is off. Check your fuse in the driver kick pannel and under the hood.
Old Aug 9, 2006 | 06:07 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">well if i'm able to still eject the cd and put it in doesnt that mean there is power going to the headunit?</TD></TR></TABLE>
Yes, but you're not reading the previous posts... You need to make sure you've got switched power on the RED wire...
Old Aug 9, 2006 | 07:20 PM
sle.simon's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but you're not reading the previous posts... You need to make sure you've got switched power on the RED wire... </TD></TR></TABLE>
sorry about that i gota lil confused so does any one have the diagram showing which fuses are which int he dashboard? the cover on my car was missing. thanks!
mnbvcxz358
Jul 1, 2008 10:54 PM
efyou
Audio / Security / Video
Mar 12, 2007 08:20 PM
phoshizzle88
Jun 8, 2006 04:29 PM
flyingduck04
Nov 24, 2005 12:10 PM
jadugartir
May 16, 2005 11:40 AM
