code 9 ??????
Old Aug 8, 2006 | 07:48 PM
crxsteve's Avatar
Default code 9 ??????
ok finaly got the rex to start but it does have gas in it so i haveit runnning off of startin fuild
but my ECU is running a code 9
i think it's a no 1 cilnder
where is that at?????
and could it be becuz i just have a stock 89 si harness on a 90 91 b18a1????
just wondering
thanks for any help
Old Aug 8, 2006 | 08:13 PM
crxsteve's Avatar
Default Re: code 9 ?????? (crxsteve)
bump
Old Aug 8, 2006 | 08:31 PM
crxsteve's Avatar
does any one know?????????
bump
Old Aug 8, 2006 | 08:41 PM
julio_bOostamante's Avatar
I'm a Jackass
what model CRx do you have? what harness are you using?? code 9 is CPS cylinder position sensor. did you do a DPFI to MPFI swap?
Old Aug 8, 2006 | 08:43 PM
crxsteve's Avatar
Default Re: code 9 ?????? (julio_bOostamante)
i have 91 hf crx with a 89 si full inside out harness
what the car fire on starting fuild just i need to get gas for the car
but i am wonding where could that sencor be at ???
Old Aug 8, 2006 | 08:45 PM
nappyroots827's Avatar
did you move the two cyl pos. sensor wires to the sensor on the exhaust cam?
Old Aug 8, 2006 | 08:47 PM
crxsteve's Avatar
Default Re: code 9 ?????? (nappyroots827)
uhm where would that be
and this is a b18a1
is that a little green plug on the back of the motor???
becuz if so i don't have that pluged in
Old Aug 8, 2006 | 09:09 PM
crxsteve's Avatar
bump
i heard that i might have to replace the whole dizzy
i don't really wunt to do that
Old Aug 8, 2006 | 09:10 PM
I'm a Jackass
that would be the blue/green blue / yellow that go on the Dizzy. only the ZC has it on the exhaust side.
Old Aug 8, 2006 | 09:57 PM
crxsteve's Avatar
well i was just messing with and i pulled the batt off for 30 secs and then put it back on and i turned the motor a few times and no code iam gonna be going to get gass when i wake up hopfully i can get this going good
later
Old Aug 8, 2006 | 10:51 PM
janz3n's Avatar
try searching.. it works wonders. use the archive button.
Old Aug 8, 2006 | 10:57 PM
salman's Avatar
disconnest and then reconenct the Ecu and dizzy harness,
Also try to press wires in the connector,
Old Aug 8, 2006 | 11:19 PM
crxsteve's Avatar
Default Re: code 9 ?????? (janz3n)
and i did try and **** came up
Old Aug 8, 2006 | 11:21 PM
crxsteve's Avatar
Default Re: (salman)
you know i was just thinking about doing that
i am gonna try it wheni wake up
becuz becuz i had some plugs undone and i tried to start it and then i fouind the plugs off so i pluged them in and i never reset the ECU
so i am gonna try that wheni wake up just befor ei go to work
thanks for the help
Old Aug 8, 2006 | 11:59 PM
EnSAn's Avatar
Default Re: (crxsteve)
I have code 9 myself (my good dizzy lockedup) anyhow on the A6 it's the TDC sensor on the dizzy. Car runs just as good for me with the code 9 but i do notice at lower speeds the car feel's like it want to take off. get crapy MPG's too
Old Aug 9, 2006 | 12:27 AM
crxsteve's Avatar
Default Re: (EnSAn)
ooh well i am gonna try to run it when i get gass and i have to put the vavle cover on it
and i am gonna change the oil and ****
i have all new plugs and i have msd cap and coil
so iam out
later
Old Aug 9, 2006 | 01:12 AM
salman's Avatar
I had no problem alse the Vtec was not engaging.
When ever you do any theek wtht the wiring reset the ECu first,
Else the code remain in the ECu,.
Old Aug 9, 2006 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante &raquo;</TD></TR><TR><TD CLASS="quote">that would be the blue/green blue / yellow that go on the Dizzy. only the ZC has it on the exhaust side.</TD></TR></TABLE>
haha your right, my bad, i just posted in a zc thread, thought thats the motor he had, woops
Old Aug 9, 2006 | 12:33 PM
janz3n's Avatar
did you try searching the archives??? bull ****. i had this problem too and searched.. plus theres a whole thing in the faq forum, has all the codes and troubleshooting. theres got to be more then 10 post about this stuff. dont be lazy.
Old Aug 9, 2006 | 07:05 PM
crxsteve's Avatar
well i saerch code 9 and **** came up
so i am not beeing lazy
and if you had the same problem then why don't you tell me how to fix it?
and not start **** about how i should of looked for it
Old Aug 9, 2006 | 10:48 PM
janz3n's Avatar
dude. i just searched code 9 using the archived button. mind you you cant search just 9 so it came up with more then code 9 but there were tons of topics. plus the faq section has this https://honda-tech.com/zerothread?id=468260 but you were too lazy to find it. im not trying to start **** .. im trying to help you. heres some more help. either your wires are switched or your dizzy is fucked and you need a different one.. find a known working dizzy and put it on your car and see if you still get the code.. but use the troubleshotting first to see if it is your dizzy. its pretty simple and when i had the problem i foudn all this stuff by my self.. so dont get all offencive and mad at me for something thats your fault.
Old Aug 9, 2006 | 10:55 PM
crxsteve's Avatar
where is the archived button at ???
becuz i did a normal serch and nothin came up
i am really new to this honda-tech thing
Old Aug 10, 2006 | 08:18 AM
janz3n's Avatar
k, sorry for being an ***. just look around on the right side of the search page.. it will say normal and archived.
Old Aug 10, 2006 | 08:08 PM
crxsteve's Avatar
ok well does this mean i need to get a new dizzy????
don't they coast like 400$$
and can i run the car with a code 9 what well it do
becuz i am still working on the car i never got to drive it yet
i just droped in a b18a1
i bought the car with no motor
but it runs just i think it needs new plugs
i haven't gone therw every thing
but every one tells me to get a new dizzy
should i ??
Old Aug 10, 2006 | 08:25 PM
crxsteve's Avatar
can i run a v-tec dizzy
or is the **** deff????
