Suspension & Brakes Theory, alignment, spring rates....
Can EK coilovers fit on an Integra?
Old Aug 8, 2006 | 07:30 PM
TURBO DC2's Avatar
Default Can EK coilovers fit on an Integra?
Are the two coilover sets that much different? What can I do to adapt an EK 96-00 coilover to a 94-01 integra?
Is it possible?
Thanks
Old Aug 8, 2006 | 08:47 PM
Voyage34's Avatar
Default Re: Can EK coilovers fit on an Integra? (TURBO DC2)
the ek uses narrower bushings in the lca that the shock mounts to.
you will have to gring the bushings down in order to make the ek shocks fit.
you will have to do this every time you replace the bushings as long as you are using those shocks.
or you could buy the parts specifically for your car.
Old Aug 8, 2006 | 10:28 PM
FalkenSiR's Avatar
Default Re: Can EK coilovers fit on an Integra? (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">
you will have to gring the bushings down in order to make the ek shocks fit.</TD></TR></TABLE>
Old Aug 9, 2006 | 03:03 AM
TURBO DC2's Avatar
Thanks for the replies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">the ek uses narrower bushings in the lca that the shock mounts to.
or you could buy the parts specifically for your car.</TD></TR></TABLE>
Other then the LCA bushings, is there are there any differences in dimensions? If i were to grind down the bushings will it effect the performance of the suspension in any way. They are OMNI power full coilovers.
Here is a pic for reference:
The bushing is too wide. If I were to grind it down, would it effect performance? Is there a difference in lengths between EK and DC integra coilovers?
Modified by TURBO DC2 at 9:54 AM 8/10/2006
Old Aug 10, 2006 | 07:01 AM
TURBO DC2's Avatar
can anyone answer that last question?
Old Aug 10, 2006 | 11:19 AM
nonsense's Avatar
Default Re: (TURBO DC2)
It shouldn't effect performance. You could also contact Omnipower to see if they can sell you two of the bottom sections for a DC/EG. They should just thread off and on.
hmtcrxsir
Oct 4, 2007 09:26 AM
tronic
Suspension & Brakes
Mar 21, 2007 02:37 PM
909ej195
Oct 22, 2006 01:10 PM
ekdriven
Suspension & Brakes
Mar 11, 2005 02:40 PM
sporkcrx
Sep 26, 2004 05:46 PM
