hood wont release
Old Aug 8, 2006 | 07:13 PM
c0nspire's Avatar
Default hood wont release
so i put some 1/2" by 1/2" spacers under the hood between the hinge and hood to lift it up twards the window (i like how it looks)
Anyways the hood wont release now. Just wondering how i can get it open and fix this problem. I think the hood pin just isnt sitting in the latch straight and its binding or something
Old Aug 8, 2006 | 07:19 PM
CoolRedXylophone's Avatar
Default Re: hood wont release (c0nspire)
the hood pin is adjustable as well as the latch parts
edit: try to pull the cable from underneath your car, youll probably have to take the splash shields off
Old Aug 8, 2006 | 07:34 PM
La EF-8's Avatar
hope yours isnt like mine and you have to have someone push down on the hood to get it to open. LOL its embarassing
Old Aug 8, 2006 | 07:38 PM
c0nspire's Avatar
Default Re: hood wont release (La EF-8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La EF-8 &raquo;</TD></TR><TR><TD CLASS="quote">hope yours isnt like mine and you have to have someone push down on the hood to get it to open. LOL its embarassing</TD></TR></TABLE>
tried that with my mom in the driveway, didnt work. alrite ill give it a shot form underneith tommorow. What am i pulling on, the exposed part of the wire, or just force the latch manually?
picture for hits... lol
Old Aug 8, 2006 | 07:53 PM
La EF-8's Avatar
i pulled on the cable with needle nose pliars and got it to open
Old Aug 8, 2006 | 08:02 PM
c0nspire's Avatar
i tried that from the inside, no go, ill have to see if i can do it from nder the car...
Old Aug 8, 2006 | 08:03 PM
La EF-8's Avatar
dang thats normally my way to get under the hood
Old Aug 8, 2006 | 08:07 PM
c0nspire's Avatar
Default Re: (La EF-8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La EF-8 &raquo;</TD></TR><TR><TD CLASS="quote">dang thats normally my way to get under the hood</TD></TR></TABLE>
hm ill try it again tommorow then, with a friend pushing on the hood
Old Aug 8, 2006 | 08:12 PM
La EF-8's Avatar
Default Re: (c0nspire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0nspire &raquo;</TD></TR><TR><TD CLASS="quote">
hm ill try it again tommorow then, with a friend pushing on the hood</TD></TR></TABLE>
that normally is the best way, i hate tugging on the cable
Old Aug 8, 2006 | 08:29 PM
c0nspire's Avatar
no ive done the hood thing already.. How much force do u think will be required?? I can already pull the hood release all the way out past what used to be the release point...
Old Aug 8, 2006 | 08:52 PM
TheSSG's Avatar
Clean up and regrease your latch, and then adjust the adjustable screw inside the spring, then it'll pop right up
Old Aug 8, 2006 | 08:58 PM
La EF-8's Avatar
thank you
Old Aug 8, 2006 | 09:43 PM
bonestock91's Avatar
b4 i raised my hood my hinge didnt even work, u can just pull up the hood with out pressing the lever. after i did the raise it fixed that.
Old Aug 8, 2006 | 11:18 PM
rayzian's Avatar
Default Re: (bonestock91)
I tried to do that to my hood (spacers).. I ended up going too far with one bolt that it snapped and left a nice pimple on the top side. Now my hood sits on 3 bolts and is uneven on one side. That right there is bad luck..
egg_baLLa
Feb 22, 2008 04:02 PM
AutoXer
16
Jun 11, 2006 11:39 PM
b00sted4dr
Jun 9, 2004 09:05 PM
Arsenal
Feb 17, 2004 03:18 PM
