Knocking noise while braking at slow speeds. Help
Old Aug 8, 2006 | 06:59 PM
d16vteceg's Avatar
Default Knocking noise while braking at slow speeds. Help
Well I get a really bad knocking noise when I brake at slow speeds. I can't hear it or feel it when I'm on the freeway and braking, only when I am coming up to a red light. Sounds horrible, I don't really feel it in the brake pedal so I'm not sure. Is there a bushing or something I need to replace? It is coming from my front passenger side.
Old Aug 8, 2006 | 07:10 PM
LerRoy1119's Avatar
Default Re: Knocking noise while braking at slow speeds. Help (B18chatch83)
Could be your rotors. Might need to get them resurfaced.
Old Aug 8, 2006 | 07:48 PM
92_VX_EG's Avatar
Front lower control arm bushing is bad. Same thing happened to me a month ago. I couldn't figure out what it was. I took the wheel off and it didn't wobble. I did the same thing the next day and it wobbled. I looked at it for a while and then I noticed it was the front LCA bushing. I put a new control arm on and everything is fine now. Somebody a couple weeks ago had the same problem, I told him to check is front LCA and that fixed his problem too. Hope this helps!
Old Aug 9, 2006 | 12:51 AM
d16vteceg's Avatar
Default Re: Knocking noise while braking at slow speeds. Help (92_VX_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG &raquo;</TD></TR><TR><TD CLASS="quote">Front lower control arm bushing is bad. Same thing happened to me a month ago. I couldn't figure out what it was. I took the wheel off and it didn't wobble. I did the same thing the next day and it wobbled. I looked at it for a while and then I noticed it was the front LCA bushing. I put a new control arm on and everything is fine now. Somebody a couple weeks ago had the same problem, I told him to check is front LCA and that fixed his problem too. Hope this helps!</TD></TR></TABLE>
Yeah me too, I'm getting my car painted so I'll check it out on Friday. Thanks
Old Aug 12, 2006 | 10:09 AM
d16vteceg's Avatar
do I have to replace the whole control are or could I just replace the bushing? Also does anyone know the price to replace just the bushing or the whole control arm? Thanks
alscrx
29
Aug 10, 2021 11:23 PM
97teg415
May 9, 2018 08:58 AM
k20eklipse
Aug 3, 2010 08:40 PM
tealchief
May 24, 2010 03:10 PM
rudeman85
Oct 27, 2004 02:52 PM
