190+ HP on stock block lsvtec?
anyone know if its been done and safe?
not sure if this will be in a gsr or b16 head
what i wanna do:
jun type3 cams
aem cam gears
portflow valveterain
multiangle valve job
thin head gasket
smsp header
2.5in exhaust
not sure on IM or valves
and it will be tuned with Crome
i wont be able to do anything to the block for awhile ,so this is the only route i can do at the moment.
o and i searched but i couldent find what i needed.
what i wanna do:
jun type3 cams
aem cam gears
thin head gasket
smsp header
2.5in exhaust
long answer: you won't be able to run cams big enough with the LS valve reliefs. Which is ok because you want much more compression with those big cams. and even if you were, you'll be stuck with a pretty low rev limiter since you'll be on a completely stock bottom end.
short answer: NO
short answer: NO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power »</TD></TR><TR><TD CLASS="quote">long answer: you won't be able to run cams big enough with the LS valve reliefs. Which is ok because you want much more compression with those big cams. and even if you were, you'll be stuck with a pretty low rev limiter since you'll be on a completely stock bottom end.
short answer: NO</TD></TR></TABLE>
Good man.
Good man.
integlspwr2k
10
Mar 13, 2006 11:05 PM
DC2SIR-G
Feb 28, 2006 07:42 AM
used2baracer
Jul 31, 2005 09:29 AM
untitled
Apr 19, 2004 11:33 AM
