CRX Si Sunroof opens doesn't close
Old Aug 8, 2006 | 06:21 PM
Rude-e's Avatar
Default CRX Si Sunroof opens doesn't close
I know it's the switch - it occasionaly closes and I've done a search and read on how to take the switch apart and clean the contacts.....but how the hell do you take the switch out of the dash?
I was being gentle (but didn't figure it out)...I don't want that brittle old plastic crumbling in my hands....theres got to be a pin or something holding it.
Any help would be greatly appreciated...
Thanks
Old Aug 8, 2006 | 07:23 PM
La EF-8's Avatar
bump for an answer
Old Aug 8, 2006 | 07:27 PM
Loserkidwac's Avatar
Default Re: CRX Si Sunroof opens doesn't close (Rude-e)
You just kind have to work it out, try pushng the bottom out and then the top, if I remeber correctly there is a tab on the bottom and top or maybe on the sides...I can't remeber, you need to push them in and then push it forward out of the dash...HTH
Old Aug 8, 2006 | 07:32 PM
La EF-8's Avatar
Default Re: CRX Si Sunroof opens doesn't close (Loserkidwac)
not my thread but thank you, some much needed info. I didnt wanna screw up and break something. CRX`s are a hard find in the junk yards down here
Old Aug 8, 2006 | 09:30 PM
Rude-e's Avatar
Default Re: CRX Si Sunroof opens doesn't close (La EF-8)
Thanks...that helps alot....it gets pushed out
anybody know where the pins are?... top/bottom or sides?
Thanks again
rexracer626
Jul 23, 2010 12:16 PM
Canadian_EF
Jun 23, 2009 07:18 PM
SamN
Apr 26, 2007 04:45 PM
AlpineCRX
Apr 17, 2003 08:14 AM
muskrat
Dec 5, 2002 08:13 AM
